Truck stopped running today, no oil, oil in the valley, can't see where it is comming from any ideas?
When you say "No oil" you mean "Low" or none in the block at all????
Sounds like a High Pressure oil leak to me. Fill it up with cheap oil first, pop the hood and have someone crank it, but check all the lines to/from the HPOP first.
I can't see where the leak is, does not seem to be from the high pressure oil lines as they are vissible and flex lines. Is there a common problem here?
