Front driveshaft/trans crossmember
Old 09-08-2011, 08:55 AM
joshz's Avatar
joshz
joshz is offline
So i have a 93 f250, lifted 4 inches, and i swapped out the front TTB front end with a solid dana 60 out of a 97 f350, and my front driveshaft sits on the trans crossmember. I just put in 4* angle shims to get it close but its still off an inch or so and i dont want to get a bigger degree shim. Any websites that make aftermarket crossmembers that will give the driveshaft more room? Im trying to avoide cutting out a half circle in the crossmember and welding a brace under it... Josh
ftlover90
12-01-2017 06:36 PM
xkpsanit
03-23-2013 12:23 PM
jas88
11-30-2010 06:15 PM
Dalton James
01-12-2009 07:31 PM
Quick Reply: Front driveshaft/trans crossmember
