Will these headers work?
Old Sep 8, 2011 | 01:34 AM
Kirbys73F100's Avatar
Kirbys73F100
I have a 1979 F250 4x4 that originally had a 400 in it. The PO swapped in a 460 from a '71 car and not very well I might add. To make the car manifolds fit, he did what everyone else does and torched the passenger side frame rail. Can someone tell me if these headers will fit my truck? I don't want fender well exit headers because I don't have enough room with the big tires I run. Thanks in advance! Travis
Hedman Hedders 89140 - Hedman Street Hedders - Overview - SummitRacing.com
Old Sep 8, 2011 | 05:37 AM
i-w's Avatar
i-w
L&L Products
if money is not much of an issue these
are probably the best headers for your truck.
Specifically designed for a 460
Old Sep 8, 2011 | 02:19 PM
Kirbys73F100
Money is the issue. I found that specific set on Craigslist for cheap. Any help is appreciated!
Old Sep 8, 2011 | 05:22 PM
NW 150's Avatar
NW 150
i don't see why not but i wouldn't guarantee it considering i don't have a 460
Old Sep 8, 2011 | 08:34 PM
79superduty's Avatar
79superduty
headers
I've been puttin 460s in the 73-79 for years, everyone dosent like spending that money for headers... all the time doing them i've only seen L&L and Hooker super comp.... the hookers are gone up latley but for $515..they are a nice header, I got years of use from them .#6841 HKR
Old Sep 9, 2011 | 07:22 AM
ford141's Avatar
ford141
That's the same headers that I have on my '79 2wd. Not sure if they would fit your 4wd though. The only thing I'd worry about is clearance with your front shaft, but your shaft is pretty low with the rocks under it right?
Old Sep 9, 2011 | 09:20 AM
2002fx4122's Avatar
2002fx4122
look at the L&L chassis exit fenders, they driver side curves sharp against the block and almost touches the oil pan. Because the steering shaft and differential is in its way. Where the headers you posted look the same on both sides. I hate to say it but I don't think they will work, I've looked at different headers for my 460 and settled on the L&L fenderwell exit
Old Sep 9, 2011 | 09:58 AM
79superduty
no they wont fit!
Amish65F100
Jul 11, 2018 06:56 PM
5X5
Sep 13, 2011 07:09 AM
CanadianBigBlue460
Mar 6, 2010 05:52 AM
jfaber
25
Jan 28, 2010 03:08 PM
1956f100
Dec 16, 2003 06:15 AM
