Transmission Feels 'Loose'
Old Sep 7, 2011 | 03:14 PM
1990FordF250Diesel's Avatar
1990FordF250Diesel
My 1990 Ford F-250 7.3 IDI's 5 speed manual transmission feels very loose when going in and out of the gears.
Is this a transmission issue, or simply worn out linkages or something ?
Old Sep 7, 2011 | 03:24 PM
85e150's Avatar
85e150
Worn shifter, bushings, shift forks are all a possibility.
Page 96 here starts the ZFs, you can see the parts involved in the blow up:
http://www.motivegear.com/pdf/LD_TRANSCAT_004_1.pdf
You should have an access panel in the floor of your truck. Once you pull that, you can pull the top plate and shifter off the trans and get to some of the parts involved.
Old Sep 11, 2011 | 08:48 AM
1990FordF250Diesel
I changed the bushing, and it now feels a lot tighter! Thanks
Old Sep 11, 2011 | 02:15 PM
85e150's Avatar
85e150
Victory over worn bushings, that's what it's all about sometimes......
nicksorenson
22
Jul 9, 2017 07:03 AM
Joe Smith94
Mar 13, 2017 02:07 PM
lvin4jc
Jan 1, 2017 06:10 PM
masseysbronco
1978 - 1996 Big Bronco
Nov 11, 2013 06:02 PM
john112deere
1983 - 2012 Ranger & B-Series
Mar 21, 2006 07:51 PM
