Fuel leak
Old Sep 7, 2011 | 02:47 PM
tritonman2001's Avatar
tritonman2001
Fuel leak
To start off with, I have been fighting a fuel leak on top the motor for a little over a month now. The problm with finding it was when it was all cleaned off it didnt leak at idle, and it only leaked under load and it sprayed everywhere in the valley. I have been putting die in the fuel at every fill up and finally today I could see where it was. Both lines coming out of the bowl, and where it went into the left head. When I took it apart the rubber sleeves were almost non exsistant. Dealership had the kit for 18.99. Got it all back together and no leaks, and I can get a puff of smoke now. Power seems boosted also. Maybe my milage will go up from 13 also.
Just wanted to report in case somebody else is having the same issue.
Old Sep 7, 2011 | 02:54 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Thanks for the info.
Grainger has those parker sleeves as well. I think they sell them in packs of 10. I plan on ordering some soon to keep on hand just in case...
Old Sep 7, 2011 | 02:58 PM
tritonman2001
Not a problem. That is what we are all here for. I have earned more on this site about these trucks than anywhere else, and if I can give help I am more than happy to.
Old Sep 7, 2011 | 03:00 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Glad you were able to find it finally. Little nagging issues like that really make a mess after a while.
Here you go for future roadside issues.
Riffraff Diesel: "Mechanics Parts Cabinet" Combo kit
Or for that issue you can buy just the fuel sleeves for under $5.
Riffraff Diesel Performance Parts: - Fuel Supply
Old Sep 7, 2011 | 03:11 PM
tritonman2001
Thanks for the links Clay. I would have ordered from you but this is the DD, and Whe I took the line off the head to see what was going on I knew that it needed them NOW and I couldn't wait.
Old Sep 7, 2011 | 04:17 PM
Riffraff Diesel
PREMIUM SPONSOR
No, that isn't an issue at all. If you would have called and asked me I would have advised you to do the same thing. I only wanted to put that out for others that will end up reading and wondering where they can get them
Old Sep 7, 2011 | 06:08 PM
PaysonPSD's Avatar
PaysonPSD
Good job on getting the leaks fixed.
Here's a preventatve measure that may save you another leak. LINK
Old Sep 7, 2011 | 07:37 PM
tritonman2001
I know you weren't fussing, I just wanted to clarify for everybody why I went to the dealer
Thanks for the link. I have already done that and the line on passenger side where the strap is at.
Spool&Go
28
Jan 16, 2015 10:49 AM
marks500
49
Feb 20, 2012 03:17 AM
3wildboys
Sep 18, 2011 11:49 PM
Copedawg
19
Feb 7, 2011 09:10 PM
why165
Jan 4, 2010 12:13 PM
