Axle id again!
Old Sep 7, 2011 | 09:50 AM
JOHNSHO's Avatar
JOHNSHO
Axle id again!
85 f250 4X4 6.9 dieselThis the only number I see on the front axle and is stamped upside down on the front pass side beam.Any gues what it is?--P 74 5 2 then 415 82 196--God BlessJohn--10 bolt pattern
Old Sep 7, 2011 | 11:25 AM
Chris72's Avatar
Chris72
I cant find anything from those numbers. Is it a kingpin or ball joint axle?
Old Sep 7, 2011 | 07:44 PM
JOHNSHO's Avatar
JOHNSHO
CHRIS
Found a tag in my toolbox. ---S 120 K--3L55 10 2 5F15--DOES THIS MEAN ANYTHIng?ThanksJohn
Old Sep 7, 2011 | 07:49 PM
bashby's Avatar
bashby
F250 should be a TTB, twin traction beam, a Dana 50. The 350's had a solid front axle, a Dana 60. The 50 uses the same hub, rotors etc, but is not as strong as the 60 because of the independent suspension. Of course the 50 TTB rides smoother.
Old Sep 7, 2011 | 08:11 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Is it a regular cab or super cab?
All Super Cab 250's had Dana50 front axles.
Most reg. cab 250's had Dana44HD, BUT some had Dana50's as well.
Easy way to tell, measure the hub...
Dana44HD - 3.5"
Dana50 - 4"
You can notice a difference just by looking at them.
Dana44 HD, my 1990 F250 reg. cab Diesel.
Dana50, 1991 F250 reg. cab Diesel
Old Sep 8, 2011 | 06:19 AM
JOHNSHO's Avatar
JOHNSHO
Dana 44
Measures 3.5 inches, so it's a Dana44....Thanks to all so much....So the 85 f250 6.9 is a Dana 44....and the 95 f250 is a Dana50....Nothing on these axles/spindles are not interchangeacle, Right? ...Both are regular cabs...How do I keep all these sentnces from "running together"?....Have a Blessed Day.....John..
Old Sep 8, 2011 | 07:27 AM
Slip ford man's Avatar
Slip ford man
You would be looking for a 7 digit number... Dana Holding Corporation - The Expert Axle Bill of Material... beginning with a 6
Lefty980
Sep 24, 2006 09:47 PM
CO4x4SD
Jan 7, 2003 09:19 PM
PSD_Power
Nov 18, 2002 12:33 PM
