gooseneck/ 5th wheel
Old Sep 7, 2011 | 12:45 AM
SuperDuty93's Avatar
SuperDuty93
Ok so since im redoing my truck now, i dont want to go back later and screw something up. Does anyone know of a 5th wheel/ gooseneck kit that i can have installed in my 1974 F250 4X4? I want the holes when im not towing anything to lay flat with the bed so i can slide stuff in over it. (kinda like the factory kit on the new 2011 Super Duty)
Old Sep 7, 2011 | 06:45 AM
teds74ford's Avatar
teds74ford
I think you would have to buy one, such as a B&W kit for a different truck and then cut/weld/modify to make it fit.
Old Sep 7, 2011 | 08:25 PM
supercabfreak's Avatar
supercabfreak
X2 on the B&W my uncle bought one for a 02 superduty and narrowed it to fit his 81 k30 and with its square ball shaft you can get 5th wheel that locks in and can be removed in 30-40 seconds
Old Sep 7, 2011 | 09:39 PM
2tone250's Avatar
2tone250
We had an Atwood on our psd that layed over and was pretty nice.
Old Sep 10, 2011 | 09:15 AM
RunninD's Avatar
RunninD
B&W makes a kit specifically for the 34" frame rails. Ford used the 34" clear into the 90's on their cab & chassis trucks. Best part, no cutting!! just a couple of holes drilled in the side of the frame. The side plates then bolt to the frame, and the top strap bolts to them. They bed winds up with a circular hole for the "Turn over Ball", and two safety chain straps. I love this hitch, and have one in all of my trucks!
Old Mar 31, 2012 | 12:59 PM
fully321's Avatar
fully321
Are you using the 1980-1996 kit from B&W? I have a '77 F-150 and B&W told me in a E-mail that I would need to order a ford center section and fab my own sides. I didn't find any dimensions listed on their website either. I'm guessing your using the 3/4 ton with overload springs. I'm trying to order the one you've used, and order right the first time. Thanks!
Old Apr 1, 2012 | 05:58 PM
RunninD's Avatar
RunninD
ya know, I don't remember which one it is. I got the last one (the one for Frank's predecessor ) from a JY off of a 90's cab & chassis F450. Frank came with a flip a ball, so I kept it, and gave the B&W to a friend
fzrider998
Dec 19, 2017 11:24 AM
slangvel
All Things Towing
Aug 10, 2017 12:54 PM
sloate9471
All Things Towing
Feb 1, 2016 09:23 PM
Segrat
6.7L Power Stroke Diesel
27
Sep 3, 2012 07:57 PM
