better start when cool
Old Sep 14, 2011 | 01:14 PM
slim613's Avatar
slim613
alright tell me if this is right, its 76 degrees here i started it up lettin it warm up while im cheaning all the shot gun shels out of my bed and all of a sudden jet nouse again i know yall said this was normal at 50 degrees but it at 76? and im in the midel of redoing my exaust so it stops right at the back of my cab 4 door with no muffler and only the down pipe bends
Old Sep 14, 2011 | 01:16 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Could a clogged ebp tube or bad ebps cause that?
Old Sep 14, 2011 | 01:24 PM
slim613's Avatar
slim613
i a got a clue on that but it could be seing that the ebpv is wat causes the jet sound so thats possibley right, would it show a drop in mpg as well?
Old Sep 14, 2011 | 01:37 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes ebp tube and sensor are directly linked to lowered mpgs
Old Sep 14, 2011 | 01:39 PM
RainStroked's Avatar
RainStroked
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
That can cause a big drop in fuel economy, and the valve definitely shouldn't be moving at nearly 80 degrees. I suspect your sensor may be bad, but give that tube cleaning a try. I'm not sure if that affects the butterfly valve at the outlet, but it's worth a shot.
Old Sep 14, 2011 | 01:40 PM
slim613's Avatar
slim613
well then i think i may have found my problem, if i hooked this up to a scaner and tested it that the sensor would show up?
Old Sep 14, 2011 | 01:55 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If you had an AE or equivalent it should show up.
Old Sep 14, 2011 | 01:57 PM
powerstroker100's Avatar
powerstroker100
where is this tube and sensor?
I would like to clean mine just to see, since my truck has 160k it is a year 2000 engine
also why do people "gut" the ebpv? what are the benefits?
Old Sep 14, 2011 | 02:00 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
The sensor is on the front of the engine. The tube wraps around the engine from the sensor to the passenger side manifold.
Old Sep 14, 2011 | 02:02 PM
RainStroked
Check the link in my above post on how to clean it.
As far as benefits, less reistriction, no more oil leak or sticky valve potential, and lower EGT's. You can't use it as an exhaust brake any longer, but other than that, you probably wouldn't miss it.
Old Sep 14, 2011 | 02:54 PM
slim613's Avatar
slim613
thanks for helping me with that now one more question during the rest off this week im not driving my truck but saturday iv gotta go to a funeral thats 400 miles away then i gotta drive my truck all next weekend so do i need to do this asap or could it wate till next weekend?
Old Sep 14, 2011 | 02:56 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You can do it when ever. It doesn't hurt anything.
Old Sep 14, 2011 | 02:58 PM
  #28
slim613's Avatar
slim613
good thanks a bunch
well other then fuel milege it dosent hurt, im gonna try sunday tho im pretty sure i still have that site u gave me
Old Sep 14, 2011 | 03:12 PM
  #29
A/Ox4's Avatar
A/Ox4
9 ECHO 1
It's really easy. The way I did it was I got some speedo cable from autozone for $8 and a can of brake cleaner. Put the speedo cable in a drill and put the speedo cable in the tube. Worked great.
Old Sep 14, 2011 | 03:35 PM
  #30
slim613's Avatar
slim613
ya that sounds like a good ol plan to do sounds good thanks
