Sponsored by: Auxito
Intake Leak
Old Sep 6, 2011 | 10:31 AM
jgeese's Avatar
jgeese
Intake Leak
Found a intake coolant leak while camping this weekend. Coming from the front left side of intake at the aluminum cross over. Added the Bars Leak and made it home without any further leaks.
If the intake is indeed cracked/broken, which is the best replacement manifold? Found the Dorman intake at Rockauto for under $200 and the Ford OEM at Partsguyed for $348.
2002 F-150 4X4 5.4
Old Dec 30, 2011 | 10:00 PM
aortizexcursion's Avatar
aortizexcursion
What did you end up going with? I need a new intake manifold and don't know which to purchase.
Old Dec 30, 2011 | 11:22 PM
jgeese's Avatar
jgeese
Turns out it was just a bad gasket!
Pulled the manifold, replace gaskets and go...
Old Dec 31, 2011 | 12:07 AM
aortizexcursion
I'm going to have to check for that with mine...glad everything worked out well for you.
Old Dec 31, 2011 | 09:11 AM
steve(ill)'s Avatar
steve(ill)
i pulled the manifold and the rubber o-ring was blown out. The groove that the o-ring sets in was damaged by errosion. Thats in the plastic manifold. I filled the groove with epoxy, flied it smooth and installed a paper gasket like you would have done on a 1980 V8 351.
Old Dec 31, 2011 | 09:12 AM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/8...d-on-5-4l.html
Keepitrunnin
Jul 19, 2014 11:16 AM
mcguyverii
Nov 2, 2013 12:01 AM
timbersteel
17
Aug 21, 2013 03:15 PM
50capri
1978 - 1996 Big Bronco
Oct 10, 2008 07:09 PM
magoo50
3.8 & 4.2L V6
Feb 23, 2007 11:37 AM
