Speedometer Drive Gear
Old Sep 6, 2011 | 10:20 AM
Mikulh's Avatar
Mikulh
Hey guys. I'm new to the forum.
I recently purchased a '61 F-100 with a 292 y-block v8 and 3-speed on the column, and I've been working on getting it in driveable shape.
I noticed that the speedometer wasn't working so I started investigating.
To make a long story short I found that the speedometer drive gear in the tailshaft of the transmission is stripped out. When I stick my finger in the hole where the speedometer cable goes it feels completely slick.
The driven gear, cable, and speedometer are all ok. (I had my wife watch the speedometer to see if it moved while I spun the driven gear by hand.)
So, how do I replace the speedometer drive gear in the tailshaft of the transmission? Also, where is the best place to purchase one?
thanks,
Michael
Old Sep 6, 2011 | 01:37 PM
66f-100's Avatar
66f-100
I had the same thing happen on one of my 4 speed toploaders. I had to remove the tailshaft in order to fix it. The gear turned out to be ok, the retaining clip (if memory serves correctly) was broken which allowed the gear to move on the shaft. You should be able to do it.
Old Sep 6, 2011 | 02:16 PM
66f-100's Avatar
66f-100
Old Sep 6, 2011 | 04:40 PM
Mikulh's Avatar
Mikulh
Thanks!
I had not considered that possibility, but that would explain why it feels slick...I was wondering how in the world that happened.
I'm thinking I can do this without removing the transmission from the truck... just pull the tailshaft. Is that correct?
Old Sep 6, 2011 | 05:46 PM
66f-100's Avatar
66f-100
Yes, you can do it with the trans in the truck. Just pull off the tailshaft like you said.
Old Sep 6, 2011 | 06:05 PM
WebMonkey's Avatar
WebMonkey
i replaced the gear on my wife's 64 f100. it had a stripped out plastic gear and i replaced it with the correct metal gear.
i dropped the driveshaft and pulled the tailshaft off.
wasn't too bad.
'monkey
Old Sep 7, 2011 | 04:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
One size does not 'fit all.'
There is more than one DRIVE gear: Could have 6, 7 or 8 teeth. Some teeth run this-away: ///// .. some teeth run that-away: \\\\\
Some are steel, some are nylon, as it depends on the application. There are different inside diameters, as the DRIVE gears are certain years specific.
DRIVE and DRIVEN gears are determined by the series, wheelbase, trans type, rear axle ratio and the tire size, which can be a pain, since the bias-ply tire sizes used 'back then' are different today with radials.
1961 F100 292 3 speed M/T could have a 3.70, 3.89, or 4.11 ratio. Short wheelbase uses a different DRIVE gear than long wheelbase.
The DRIVE gears have stamped ID numbers marked on them.
Old Sep 7, 2011 | 05:49 AM
66f-100's Avatar
66f-100
On my toploader, there was also a ball bearing that sits "halfway" into the shaft and fits into a corresponding groove on the drive gear. The retaining clip keeps everthing in place. I was lucky in that i found the ball bearing thingy in the tailshaft when i took it off.
Old Oct 22, 2011 | 12:15 PM
Ken Barnes's Avatar
Ken Barnes
I have a 1963 unibody and a similar problem with the cable on the manual transmission. Does anyone know what to look for. I see the top of a plastic gear in the hold but no place to put the end of the speedometer cable. Help! Ken Barnes at kenbarnes54@gmail.com.
Old Jun 9, 2020 | 04:31 AM
ODOWNIE's Avatar
ODOWNIE
I see this thread doesn't solve the question.
My 63 unibody is a 3 on the tree.
LMC have 6 different types of speedometer drive.
Can anyone point me in the direction for how to determine which one will be correct.
Is there an easy/obvious way to to tell?
Old Jun 9, 2020 | 09:06 AM
TA455HO's Avatar
TA455HO
Lead Gopher
There are a few things that factor into speedo gear selection
Year
Rear Axle Ratio
Transmission
Tire Size
All of the gears in the MPC assume bias ply tires, but most everyone runs radials these days so you have to also do a tongue in cheek estimate as to the bias ply size equivalent of radials. So, there is a little guess work to it even after you nail down some specifics.
anderson sc
Apr 29, 2010 10:56 PM
kona56
Apr 5, 2010 02:13 PM
schaad25
Apr 15, 2007 11:03 PM
TXDod65
Apr 19, 2006 11:26 AM
pinguin
Nov 21, 2003 10:16 PM
