I have an auto/tilt column in my '70 that I am suspicious about being the original column. The harness plug has been cut off and it is wired straight into the trucks harness. I got the truck this way. No ignition switch in the column. It is a Ford column. The problem I have is the lower bearing is bad and needs replaced. Have no idea what bearing I need.
Optional tilt wheel (not standard equipment on Lariats or any other models) introduced in 1978 F100/350's, Econolines and Bronco's. Operates off the turn signal handle by pressing it forward.
1978/79: The NSS is on the transmission / 1965/77: The NSS is on the column.
C3DZ-3517-A .. Steering Column Bearing / Available from Ford.
Possibly. There is one at the top and one at the bottom of the column. I have play in the steering and when checking I found the bad bearing allowing the steering shaft to move up and down before ever moving in a circular manner. Clear as mud? You should be able to move the wheel up and down if your upper bearing is bad.
Like you guys say, the top-line Rangers and Lariats are the logical place to source one of these tilt columns but I've found the '78/'79 Explorer package models are also a good place to look. They're hard to miss with the extra striping usually on them and I've seen more with tilt than without; a poor man's Lariat, if you will...
Mike I wonder if it has anything to do with location, while I have seen many explorers I don't recall ever seeing a tilt in one. I can imagine that it would have had a hefty add on fee in 78/79. The Lariat was the bossmans truck loaded to the hilt & not a lot of them in NC.
That's a good bet, John. Alberta's the biggest truck market in Canada much like Texas is for the US. Good oil and farming revenue probably was a cause for dealers to load these trucks up when ordering. So far, among the Explorers of that vintage I've come across here, and it might just be a fluke, it's running 6 to 1 in favor of tilt equipped. I had a very nice '79 460 F150 Explorer with tilt a few years back.
