Major problems (sorry, long post)
Old Sep 5, 2011 | 01:04 PM
91 Dually's Avatar
91 Dually
Hey guys......... some of you know, I have been repairing, upgrading my engine for a while now. What started all this was when I went to start truck one morning and was hydrolocked. Discovered oil in coolant, and coolant in oil... Long story short, I tore it all down to the block. Had heads totally rebuilt. Sent injectors and had them upgraded to stage ones. Sent HPOP to upgrade to T500 Terminator. Replaced oil cooler orings. Cut crossmember to remove oil pan and front cover. Discovered Front cover gaskets were leaking. When left head removed, discovered previous owner dropped glow plug tip into rear cylinder on left bank. (piston kinda banged up) Have been trying to start engine (no luck yet) with no water in system... filled coolant system with water. Engine hydrolocked again. Removed glow plug in left rear cylinder, cranked engine... blew water everywhere.... This water has gotten in there with no pressure whatsoever on system. Cap not even installed.. Gravity flow only... Cracked cylinder wall? I can see no other possibility
Old Sep 5, 2011 | 02:05 PM
fordpride's Avatar
fordpride
It can only be head gasket or cylinder
Old Sep 5, 2011 | 02:14 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Yikes, sure sounds like it to me.
Old Sep 5, 2011 | 10:35 PM
rusty9cab's Avatar
rusty9cab
That glow plug may have cracked the cylinder wall and it may need a sleeve. That sucks if that is the problem. Maybe drain the coolant and do a compression test on all the cylinders to make sure. Hopefully it is something else.
Old Sep 9, 2011 | 03:36 PM
91 Dually's Avatar
91 Dually
Update today
Well, my worst suspicions have been confirmed. Drained most of the water. Pressurized the system to 15 psi. This is the view down the injector hole...... see bubbles? Can you say "cracked cylinder wall"?
I guess now I need to find a block, or see about having this one sleeved.. CRAP!!!
Old Sep 9, 2011 | 04:52 PM
fordpride's Avatar
fordpride
Chase (superduty4x4)has or did have a low milage long block for sale
Old Sep 9, 2011 | 05:00 PM
DIYMechanic's Avatar
DIYMechanic
Are you sure it isn't just a blown head gasket leaking coolant into the cylinder?
Old Sep 9, 2011 | 07:37 PM
91 Dually's Avatar
91 Dually
Just bolted newly rebuilt heads on, new gaskets, new bolts. haven't even started yet. The pic is looking down into the cylinder through the injector cup. The piston is down a couple inches. The bubbles are coming up from around / beside the piston.
Old Sep 9, 2011 | 08:33 PM
Talyn's Avatar
Talyn
its not injector cups either?
Old Sep 9, 2011 | 08:50 PM
540milotalon's Avatar
540milotalon
Sleeve sounds cheaper, trouble is finding a machine shop anymore. Where a bouts in WVA is "Cross Lanes"?
Old Sep 9, 2011 | 09:39 PM
91 Dually's Avatar
91 Dually
No, wish it was the Just the injector cups.....cross lanes just west of charleston
bigelkhunter
Dec 7, 2013 10:44 AM
97250towtruck
Nov 22, 2010 03:11 PM
2005f-150
Jul 20, 2010 10:29 PM
tmroper
Apr 12, 2005 09:12 AM
68Mercury250Ranger
Sep 13, 2004 10:44 AM
