Number Dummy
Old Sep 5, 2011 | 10:29 AM
Lightning5's Avatar
Lightning5
Number Dummy
I need some help on a brake problem. I have a 65 F100 that i put disc brakes on, the installing went without a hitch, brakes work fine, good pedal,etc. The problem is I can,t lock the brakes up on asphalt, they will lock up on hard dirt. Everything was bought from NAPA for a 1976 F100
except the spindles they was bought from a fellow in Washington state and he gave me a used proprotional valve, I am thinking the pro valve
may be the Problem?? if the rear brakes locked up when all was drum brakes, why want they lock now, nothing was changed on the rear.
Wouldyou give me the correct part number for a 76 F100 porporitional
valve, maybe I can find one, was they the same for other year models?
Bill, I will thank you now, I have read a lot of your posts and I appreciate
all time and effort you have put in to the information you put on this site.
Old Sep 5, 2011 | 12:49 PM
camperspecial65's Avatar
camperspecial65
the m/cyl on the 66 is a single cup reservoir...1 line fed front and rear...after that seperated front and rear reservoirs..front brakes do the majority of the braking on cars n trucks...thus front reservoir on many rigs is larger then rear. The prop valve could be bad...or it might not have been from same rig as rest of setup...assuming it is, it could be bad...I believe theres a switch in/on them that is the switch telling you you got failure in one or both ends...that could be bad...Im not sure if its intergral with prop valve or not...did you change your rear brake hose ?? It could be a partial cause to the problem as well if its collapsing inside....
Just my 2 cents....
- cs65
Old Sep 5, 2011 | 01:32 PM
85e150's Avatar
85e150
Did you install the dual master cylinder with the disc conversion?
Disc brakes need more pressure than drum.
Read through this regarding master cylinders, residual valves etc:
Brake Article© by Dean Oshiro
Will your fronts lock up?
Old Sep 6, 2011 | 05:56 PM
66f-100's Avatar
66f-100
Did you bench bleed the new master cylinder? If you don't bench bleed it before installing it, you may not be able to get all the air out of it and it won't work properly.
Old Sep 7, 2011 | 05:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I believe theres a switch in/on them that is the switch telling you you got failure in one or both ends that could be bad...I'm not sure if its intergral with prop valve or not
Or not.
C8AZ-2B264-A .. Plastic Low Brake Fluid Warning Lamp Switch / Available from Ford.
This little charmer is a POS, develops cracks in its threads. When this occurres, brake fluid seeps out, the low brake fluid warning lamp on the dash comes on...and stays on.
Applications: 1968/79 F100/350 & Bronco / 1969/79 Econoline / Misc 1968/70 FoMoCo Passenger Cars (1967 is one year only: C7AZ-2B264-A).
Since nothing prior to 1967 had the warning lamp, just leave the switch in place to plug the hole...hope it doesn't start seeping.
D5TZ-2B257-B .. Brake Differential Proportioning Valve / Marked: D5TA-2B524-FA or FB / Obsolete
Applications: 1975/79 F100/150 2WD & E100/150 / 1975/79 F100/150 4WD & 1976/79 Bronco / 1975/79 F250 2WD w/single piston calipers / 1978/79 F250 4WD / 1979 F350 4WD.
Old Sep 7, 2011 | 08:50 AM
Lightning5's Avatar
Lightning5
THANKS fellows for all the Information Lightning5
Old Sep 7, 2011 | 08:54 AM
Kep4's Avatar
Kep4
Jäger
Got to give these guys, especially NumberDummy, some positive Rep for their assistance!
Old Sep 7, 2011 | 08:12 PM
Kep4's Avatar
Kep4
Jäger
This is why you give positive Rep to Bill (NumberDummy) and others that help! Click on the red heart in the upper right corner of his post.
Old Sep 7, 2011 | 10:01 PM
Lightning5's Avatar
Lightning5
Thanks for the info. Did not know this.
Old Sep 8, 2011 | 08:19 AM
Kep4's Avatar
Kep4
Jäger
You're welcome!
Old Sep 27, 2011 | 10:21 AM
Lightning5's Avatar
Lightning5
ND, the literature I have on the valve D5TZ-2B257-B says that the Metering valve part
can be replaced, does your breakdown on this valve show a part number for the
metering valve? Do you think anyone would have this part?? THANKS
Old Sep 27, 2011 | 06:29 PM
NumberDummy
ND, the literature I have on the valve D5TZ-2B257-B says that the Metering valve part can be replaced.
What literature might that be? It's not from FoMoCo.
The only part of the prop valve that was replaceable by itself was the low brake fluid warning light switch....that's it.
If there was a part number for a metering valve, I would have known about it, and so...would have listed it.
Old Sep 27, 2011 | 09:22 PM
Lightning5's Avatar
Lightning5
Bill, I have got to go with you on this, I know from your posts you have the numbers, THANKS I will hunt another valve to replace this one.
Here is the link I got the information from, read what it says about the
Metering valve, I have trouble with the front brakes and thats where I came up the question. THANKS again.
FORDification.net Forums • View topic - Brake Combination Valve (a.k.a. Proportioning Valve)
Old Sep 28, 2011 | 04:06 AM
NumberDummy
The guy that typed that jazz needs to look in a Ford parts catalog.
He claims: all trucks with front disk brakes have a combination valve, mistakingly called a proportioning valve.
Correct Ford terminology: Brake Differential Proportioning Valve.
More mis-information: If defective, a metering valve is serviced as a replacement.
This only applies to 1968/72 F250 2WD's and F350's with optional dual piston caliper disc brakes.
The metering valve (C8TZ-2B161-A) was available by itself, because it was a separate part. It was not part of the Brake Differential Proportioning Valve.
This metering valve has a bracket made as part of it, bolts to the left (drivers) side outer frame rail, adjacent to the engine crossmember.
Wanna see the puppy? Look here: 1964/72 Ford Truck Parts Catalog / Illustration Section 22, Page 16.
Old Feb 6, 2012 | 07:26 PM
fordpt's Avatar
fordpt
Brake lines
Hello I would like to put Stainless brake lines on my 1966 F 250, the lines are only made for F100 and 150?. Would any one know if the lines are different?
