Routing Scan Gauge 2 wire
Old Sep 4, 2011 | 08:37 PM
Randy777's Avatar
Randy777
Got my new Scan Gauge 2. Where have you guys ran the wire so it is out of the way? Thanks for all the help I have recieved on this new toy.
Old Sep 4, 2011 | 08:52 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Not sure where you have decided to mount it. I just have mine down by the brake controller with the velcro, just below the little cubby. From there, I just ran the cable back behind the brake controller and zip tied up near the OBD port.
Old Sep 4, 2011 | 08:57 PM
Randy777's Avatar
Randy777
I hope to mount it on the dash on the left side. I'm a real gauge watcher and need it so I can still watch it while still able to view the road. My wife took the GPS away from me and moved it to her side so I wouldn't be constantly glancing at it.
Old Sep 4, 2011 | 09:00 PM
amdriven2liv
It wasn't so you would quit watching it, it was so SHE can tell you where to go!! LOL
Just kidding.
But I now understand why you are moving it as far to the left as you can.
I've seen some pictures of SGII and Edge installed over there and I'll see if I can find them.
Old Sep 4, 2011 | 09:15 PM
amdriven2liv
Maybe, just a thought here. Might need to make a little mod on the pillar. Run the wire down from and through there, like a person would with pillar gauges?
Check the Edge website and click on the (i) next to the Edge CTS for Ford. It shows how to run the cable from there.
Edge Products| Installation (scroll down for Ford)
Old Sep 4, 2011 | 09:43 PM
High Binder's Avatar
High Binder
Mine is mounted to the top of my rearview mirror with 3M 2x tape. The CAT5 runs up into the headboard and down behind the A-pillar then behind the dash to the OBD port. Obviously I added about 5' of CAT5 to it.
Old Sep 4, 2011 | 10:29 PM
BLADE35's Avatar
BLADE35
Hey Randy
just curios how the SG reads compared to your Issopro Gauges
boost was one I was wondered about
thanks Randy
Old Sep 4, 2011 | 10:51 PM
Randy777's Avatar
Randy777
Thanks guys I have run the cable. The Edge installation instructions were very helpful. Your right about my wife she is always telling me to keep my eyes on the road. I will certainly post the difference between my Isspro gauges and the Scan Gauge once I get it going.
Old Sep 5, 2011 | 05:36 AM
robert421960's Avatar
robert421960
i mounted mine on top of the steering column and i love where it is.i can see everything except what gear im in.the cable was super easy to run that way too
Old Sep 5, 2011 | 07:20 AM
rattleNsmoke's Avatar
rattleNsmoke
I ran my ScanGauge cable under the steering column then down to the OBDII port. The gauge is mounted above my left knee on the panel just below the headlight switch.
Old Sep 5, 2011 | 12:01 PM
HowarD1's Avatar
HowarD1
Blend Mount makes a nifty device that will mount it neatly above your rearview mirror!
Old Sep 5, 2011 | 05:57 PM
jimmyv13's Avatar
jimmyv13
The blendmount is pretty slick, but a bit pricey at ~$50.
Old Sep 6, 2011 | 08:49 AM
Misky6.0's Avatar
Misky6.0
Yes, but I had mine in the cubby for 4 months and I found I was
constantly looking down while driving. Now with it above the
mirror - I check it along with the mirror and now it's not a distraction.
It also comes with an extension cat-5 cable and all the Hw needed
I would recommend it.
Old Sep 6, 2011 | 09:54 AM
jimmyv13's Avatar
jimmyv13
I was wondering how the cat5e coupler works compared to extending the cable....as in does it slow down the signal with the coupler?
Old Sep 6, 2011 | 10:20 AM
Misky6.0's Avatar
Misky6.0
I've had no issues with it at all, and since it came with the blendmount
it's sort of a non-issue to me.
