Underheating?
Your cooling system should get just as hot, anti-freeze or no anti-freeze. We all learned in high school that the pressure in the cooling system increases as the temperature increases, but the amount of pressure doesn't have anything to do with where the boiling point happens to be. Anti-freeze is simply added to spread the range of temperatures that the coolant remains in liquid form. Some people don't run anti-freeze at all because they know that the coolant will never experience freezing temperatures in their climate, and they don't expect to run their engine near the boiling point of water. However, anti-freeze should always be used in general because about 5% of it is composed of rust inhibitors.
I think you're over-reaching here. I'm also not a chemist, so I'm more than happy to be proven wrong.
1) Drain coolant.
2) Flush cooling system.
3) Refill with original green coolant mixed 50/50 with distilled water.
4) Refill.
5) Crack open beer.
If you don't have any input relating to my problem, then just click over to another thread huh?
I'm trying to figure out how to get my engine to run at a nice constant 190*, and it does not yet do that. That's it!
Fmc, ya that might have been a little contrived, my last post. But what I was getting at, was not that the water's boiling, turning completely to a gas, but that it's releasing water vapor. Like a pot on the stove steams long before it boils. My *guess* was that the higher the boiling point (thanks to more coolant), the less vapor the mixture gives off at any given temp. Vapor can get through the little imperfections in the thermo seal easier than liquid, and so to me, the more vapor, the more leakage. That vapor then condenses in the radiator (think moonshine still), and flows back into the engine as cooled liquid. All this is happening before the thermostat opens keep in mind. That's what I'm talking about here. Thermostats leak a decent amount I found out.
Ya, I know that's a little out there, but it's a theory, and a pretty quickly thought up one. A theory can change in a minute, I'm not puting this down as gospel, just keeping this thread updated with my process.
However under cooling was which is a condition and actually can cause sludge and motor break down the right ratio of coolant to water allows the water to warm faster than pure water without significantly affecting to boiling point, so long story short water only no coolant will cause a slower warm up along with lack of a fan clutch (which contains a thermo-reactive bi metal coil spring to engage clutch) is why you have under heating.
One last insert a thermostat actually uses a wax pellet to expand and open, the metal spring sets the pressure to keep it closed.
let me know how you fair and if you need a tester hit harbor freight with 30 bucks
Ps i belive autozone will do these as a loaner tool
Contrary to what fmc400 says (no offense, I respect your opinion), pressure has just as much to do with boiling point as temperature does. Pressure is controlled by your radiator cap. Caps are cheap, change it out with a new one to eliminate that possible problem. Theoretically if your cap is sticking it could cause almost as much trouble as a sticky thermostat.
To expand: "The boiling point of an element or a substance is the temperature at which the vapor pressure of the liquid equals the environmental pressure surrounding the liquid". The boiling point of water is only 212 degrees at sea level (1 bar, or 14.7 psi). Compare that to the boiling point of water at .5 psi as being 79.6 degrees, or the boiling point at 48 psi to be 279 degrees. Your radiator cap keeps your cooling system at pressure, which in turn raises the boiling point of your coolant.
If you replace the cap and bypass your heater core and your temperature still fluctuates...well then I'm stumped.
Ditto, this thread was answered many moons ago.
Just go crawl in a hole somewhere and spare us all.
FYI though, to the other posters, the radiator cap is almost brand new, less than a month old, and is a 13PSI. And right, I'm gunna bypass the heater core at some point, but for the moment, the coolant has helped. That's the long and short of it (and one reason I'm so amaaazed that these couple ********* keep coming back). I'm not making this up guys, very weak mixture heated up to far less than a very strong mixture. That's just what it is!
This thread has really surprised me. It's like schoolyard bullying in here. You're either so bored, or so ignorant that you can't see how much of a fool you make of yourself. Again, do you think I'm making this stuff up? Do you really think I am unaware of how to change my coolant?! I'm gunna keep it coming though until I figure out eXACTly how to manipulate my engine's cooling and heating, so you guys are just gunna have to grit and bare it haha. And finally, once again, I'd loooove to see the couple of you that are just here to stir up a mess say any of that to me in person. I'm 6'3", 225, and I've squashed many a bug when they've deserved it, but I guess our keyboards are the same size, so you use the net as a way to get even with someone you'd feel intimidated by in real life. Well, enjoy! Hope you get all the thrills you'd hoped for piling up on a 20 year old trying to learn, but like, how can you have any self respect? You wouldn't even call me on the phone haha, like really? Geez, there's quite the broad range of people in this world I guess.
Thanks for all the VALID input here though everyone else. I knew that pressure affected boiling point (that's how a steam engine's boiler can get liquid water to 400*F), but didn't know how MUCH of an effect the relatively low pressure in a radiator could have. All of the readings on this thread though, have been since the new cap has been installed.
Anyway though, I'll keep this up to date, and a final word for those who have nooothing to contribute here, aren't you the ones spamming the board? See ya later, AleX
If you think there is a problem with his mental health and do not wish to help, then kindly excuse yourself from the forum. You are not convincing anyone but yourself.
Not my fight, but your posts have not exactly advanced the thread.
two things happen when you add coolant instead of straight water. The surface tension changes and the rate of heat transfer changes.
It is possible that the coolant is better able to absorb the heat from the engine and transfer it throughout the entire cooling system more efficiently. The net result would be a higher minimum temperature seen by the gauge. The coolant will also be a more even temperature system wide. You will also be able to transfer more heat to the radiator thus improving the high end temps you have been experiencing as well.
cheers.
