PLEASE HELP MAJOR PROBLEM
Old Sep 4, 2011 | 02:47 PM
96power's Avatar
96power
Hey i have a 1996 f250 7.3 4x4
The day of the problem i jump started my moms 1999 ford explorer 4.0 v6 maybe this caused everything i dont know?
Ten mins later she called and said she was broke down well i got there and her alternator had went out so on the way to get a new one my truck through a check engine light and it started missing and stopped in the road. I cut it off and ran my programmer to see what the code was and the only one was P040 exhaust back pressure code which has always been on there and never set a check engine light, and there wasnt any other codes on there. So i cranked it up and the light went off and i made it to the parts store and they ran a D tool also and it would not show any codes. So i drove it home and i took the exhaust back pressure sensor off and cleaned it and the pipe and when i cranked it up it just started hopping like its way out of time or something so i next went and got a cam position sensor put it on and the same thing, so i got another one because i know they made a few different ones that year and still the same thing. Could jump starting her car have blew up my pcm, or could i still just have the wrong cam sensor or could the exhaust back pressure be doing this. Please i really need help i dont have alot of money and Im 18 years old and i leave Sept 10 to go to college at Nashville Auto Diesel and this is the only vehicle i have and i really have to get it fixed so any help would be greatly appreciated. Thank You and God Bless
Old Sep 4, 2011 | 03:16 PM
Action4478's Avatar
Action4478
Sounds like a coincidence , my bet it is a burned or loose under valve cover harness ...Next time its missing , unplug the valve cover connections one at a time . the one that makes the least difference in the way it runs is the bad one . It can also be the IDM , take it out and shake it , listen for water .
If you can do a buzz test , it will help get the code ...
Old Sep 4, 2011 | 04:52 PM
bad12jr's Avatar
bad12jr
The parts store scanner wont read a stroke. Where did the cps come from. How hard were you on it when the Cel threw. What programmer do you have? And make sure the fuel filter is clean.
Old Sep 4, 2011 | 05:48 PM
96power's Avatar
96power
i wasnt running it hard hard at all just driving normal i order the international one from dfuser.com then the other one came from advance auto parts the prgrammer is the edge evolution and i havent ran the programmer in about two mouths and im going to check my fuel filter in the morning
Old Sep 4, 2011 | 09:19 PM
DRRXR's Avatar
DRRXR
Just for grins
Unplug the EBP sensor and see how it runs and let us know.
Old Sep 4, 2011 | 09:51 PM
96power's Avatar
96power
When i was cleaning it and had it off i started it up and it done the same thing and i put in reverse and it would hardly move.
Old Sep 4, 2011 | 09:54 PM
96power's Avatar
96power
if you go to youtube and type in ''powerstroke bad cam sensor'' its doing the same thing the truck is doing in this video. the truck in the video has stacks and it is white
yeomansjon
May 21, 2012 09:55 AM
96power
15
Sep 7, 2011 10:15 AM
PP Stroker
16
Feb 1, 2010 03:04 PM
2millwork
16
Jan 28, 2010 11:27 AM
meko72
Apr 15, 2004 12:18 PM
