First Ranger
What I have is a :
2001
Edge package
4x4
4.0 v6
auto tranny
brand new tires
200k mile truck
Before making the trade I tested it pretty good and seemed to do just fine. Just not sure what things I need to look for? I'm not use to having a vehicle with so many miles. I know the truck makes some noise while driving and previous owner said it was a u-joint, but haven't had a chance to look it over. I will be checking and changing fluids/filter as needed.
Also, are these trucks always so gutless? I know its only a v6 but my car has a ton more pep.
Thanks in advance!
I agree, it's a good idea to begin with changing All of the fluids & filters.
Note that the 4.0L is specified to use 5W-30 engine oil, NOT 5W-20. This is because the 4.0L & a few other engines never got an upgraded oil pump thats capable of supplying the needed flow of the lower viscosity hot 5W-20.
If you change the rear differential lube & have the "Traction Lock" rear end, be sure to use the specified synthetic gear lube AND 4oz of the Ford specified friction modifier, to prevent chatter/shudder.
As this is a 4X4, if it has the two piece rear drive shaft, make sure to check/lube it's splines with the TSB specified PTFE loaded lube product, as the splines are known to dry out & freeze/rust up & bind, to cause a driveline "thunk" on take off when torque is applied.
Also, seeing as how 01 was the first year for the OHC 4.0L in a Ranger, you'll want to find out if the timing chain tensioner has been replaced with the modified tensioner, as it was a noise source that sorta sounded like spark knock, or a diesel wrist pin knock, piston slap, or marble noise.
Be sure to check the PCV valve & it's rubber hose, as the hose is known to dryrot/crack underneath out of sight in the bend & cause a hard to find vacuum leak & driveability problems. At 200K the PCV is Way past due for a change if it hasn't been done.
Some 4.0L's are prone to Combustion Chamber Deposit Interference (CCDI), because of sloppy factory control of build up of tolerances, so the piston crowns can contact the head through the build up of carbon deposits on piston crowns & the head, in the "squish zone" on a cold start, until things warm up & expand enough to give clearance, so that type of noise goes away as the engine warms up. Ford has a 4.0L TSB decarbon proceedure for the condition, but I've found a way to get lasting results without having to replace the oil, filter & plugs as specified after doing their proceedure. Use the 20oz size Techron Concentrate Plus in the tank at the pump before filling up with Chevron, Texaco, or CalTex gas, which already have some Techron in them, so this will raise the treat rate 10X above the pump gas alone. Then do Fords TSB specified daily blow it out at rpm's above 3500 for 2-3 miles spirited type driving during the treated tank & run most of the treated tank out. That will usually get the job done in one tank without having to change the plugs, oil & oil filter. I typically do this 1-2 times a year to keep my CCDI in check.
Ford has now specified the fine wire iridium enhanced center electrode, with platinum pad side wire spark plug. They will offer up faster starts & hold the specified spark gap WAY longer than the OEM single platinum plugs, or double platinum plugs, in the 4.0L "waste spark" iginition system, which works our plugs Twice as often as the old distributor ignition system, or the COP ignition system. So opt for the Motorcraft, or Autolite iridium enhanced plugs & Motorcraft plug wires for best performance.
I'm running these plugs in my 99 Ranger 4.0L & 94 Taurus 3.8L & have noticeably faster starts year round. I also opted for OEM plug wires on both vehicles, as they are of very good quality & match the ignition systems impedence requirements.
With 200K on this ride & you reporting it being sluggish, I'd also consider pulling the MAF sensor & cleaning it with CRC, or Valvolene MAF sensor spray cleaner. Let it cool before cleaning, don't poke the sensor wires with the spray wand, keep it squeeky clean when reinstalling & see how it goes.
Seeing as how you like to turn your own wrenches, be sure to check out the "Tech Info" thread atop this forums thread listing page, for all kinds of maintenance/repair info.
At the bottom of the Tech Info page is a link on how to easily do a full tranny fluid pump out & with 200K I'll bet the tranny needs it.
The OHC 4.0L isn't wimpy, so something isn't right with it if it is, so a good tune up to factory specs with new fluids & filters as you've proposed, is a good idea to begin with imo.
A bunch of thoughts for consideration, let us know how your Scheduled Maintenance service goes & how the sluggish condition responds.
The tires are oversized so that may be some of it.
I ran the codes for the CEL and it came back with P0401 and P1401. Which seems to be more of emission issue that performance affector I think.
Hopefully I'll have the time soon to do the other maintenance needed. It is a 2nd vehicle at the moment.
What kind of mpg can I expect from this ranger? Should it get 15 in town and 20 hwy? Kind of sad that a fullsize truck will do that.
