Shifting problem
Old Sep 3, 2011 | 08:18 PM
Paul T's Avatar
Paul T
Shifting problem
I have a 96 F250 SB Crew with a 460V8. I have noticed lately when it goes to shift around 30-35 it acts like it can't find the gear. It stumbles a few times and I give it some gas and it finally goes into gear and there is no other shifting problems. It only does it around 30-35mph. Any ideas?
Old Sep 3, 2011 | 11:44 PM
DBGrif91's Avatar
DBGrif91
Absolutely not giving you something solid to go after, but just throwing this out there- torque converter clutch?
Old Sep 4, 2011 | 04:04 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » Throttle Position Sensor (TPS) Here is a link on how to test the TPS.
You don`t say what trans you have but assuming it is the E4OD then a bad spot on the TPS would be my guess.
Old Sep 4, 2011 | 12:33 PM
Paul T's Avatar
Paul T
First things first I will check the air cleaner according to the link you gave me then I will go from there. The truck has spent a lot of time in the hay field lately so the air cleaner might be the culprit. Thanks for the responses, I will let you know the results.
custom1106
2009 - 2014 F150
Mar 4, 2018 10:19 PM
cjgodden
18
Apr 17, 2017 06:12 PM
My Good 'ol 92
30
Apr 11, 2012 10:36 PM
rupejosh
18
Aug 10, 2010 10:02 PM
