Odomiter DTC code
Old Sep 3, 2011 | 11:49 AM
JonArmy's Avatar
JonArmy
Odomiter DTC code
I used the trick to show information on my 04 F350 SD 4x4 KR, I was going through the items and showed DTC 5284 was flashing, I have a SG II, and had it look for any codes but it was showing no codes. I looked the code up and it was for "oil pressure switch fail", was could be causing this error without SG II showing anything and is there a way to fix it?
Old Sep 3, 2011 | 12:27 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Interesting question. I think it's common wisdom that the oil pressure switch isn't used by the PCM and isn't visible to the SGII. So it's not suprising to see no code on SGII. The odometer trick sounds cool! Is there a DTC list for the codes? If the switch has failed seems the gauge wouldn't be working or would be wrong.
Old Sep 3, 2011 | 12:43 PM
JonArmy's Avatar
JonArmy
I can't find any odometer DTC codes,
Odometer Trick
is how to do the trick, you can even watch the tachomiter reading versus looking at the needle. I might try plugging in my handheld reader and if it shows, I'll try clearing the code and see if it comes back up, if it does I take it to the dealer since it's under warrenty
Blueswede
6.7L Power Stroke Diesel
Jul 14, 2019 10:45 AM
turboftw
Mar 24, 2009 07:37 PM
Antelope V-10
Modular V10 (6.8l)
Aug 5, 2008 04:46 PM
n1hle
3.8 & 4.2L V6
Mar 13, 2004 08:40 PM
gnfshn1218
Bronco II
Oct 27, 2003 01:42 PM
