Glow plug dash indicator
Old Sep 3, 2011 | 03:16 AM
p12483's Avatar
p12483
Is everyone else seeing their glow plug indicator everytime they start their truck? I noticed that mine is not coming on at all. I I live in fl and realize the weather would not require the plugs to activate but I remember it used to come on. Anyone else having th same problem? I remember it did light just momentarily to indicate the lamp worked. But has stopped everytime now.
Old Sep 3, 2011 | 05:35 AM
dbc001's Avatar
dbc001
Mine always lights on the first start of the day. It may not light on subsequent starts ... Guess the engine is warm and he knows they are not required. I would be surprised if yours never lights .... even in fla. Take it to the dealer and have it checked out.
Old Sep 3, 2011 | 08:18 AM
p12483's Avatar
p12483
You were right mine only lights on the first non remote start. Forgot how much I have been using that nifty thing. But went out first thing this morning it did light. Thanks for the help.
Old Sep 3, 2011 | 12:31 PM
2horses's Avatar
2horses
I rarely see mine either, first start of a 100+ degree day is usually the only time it shows up.
Old Sep 5, 2011 | 08:38 AM
Sgt93's Avatar
Sgt93
This truck is far from being my old Cummins where I turned the key partially, got my coffee and came back and started the truck LOL.
Old Sep 5, 2011 | 08:55 AM
dschuffert's Avatar
dschuffert
I am the same as everyone else on here. My glow plug light comes on for the first start of the day and then I never see it again. I bought my truck in April so I haven't seen any really cold whether with it yet. I expect to see it on more often in the Winter.
Old Sep 5, 2011 | 11:01 AM
BCooke's Avatar
BCooke
I want to say the longest I have seen mine on is 2-3 seconds, other times I do not see it. In the beginning I actually had to look in the book to see where it was. And I agree with Sgt93, I use to have a 79 GMC in Northern MN, If I forgot to plug it in.......
Old Sep 5, 2011 | 03:35 PM
dbc001's Avatar
dbc001
2horses ... LMAO at your signature .... now where did you get that
Old Sep 5, 2011 | 06:03 PM
Tom's Avatar
Tom
Good question...
Of course you wouldn't have any idea, would you?
Old Sep 5, 2011 | 08:02 PM
Painted Horse's Avatar
Painted Horse
The ceramic glow plugs in the 6.7L go from static temps to 2000* in less than 2 seconds, Not much need for the indicator light or to wait for the plugs to get up to temp.
Old Sep 5, 2011 | 08:24 PM
Tom's Avatar
Tom
This has been discussed before, I just did a search and found more info:
Originally Posted by PowerStrokeHD
It should be noted that the wait-to-start indicator on-time is controlled by the PCM and is independent from the GPCM on-time.
If the ECT is below 140°F (60°C), the GPCM energizes the glow plugs immediately after the key is placed in the ON position. The on-time is controlled by the GPCM and functions on the basis of the engine RPM, engine torque, engine coolant temperature, air temperature, BARO sensor and battery voltage. The primary ones are battery voltage and the engine coolant temperature.
Additional tidbits...
The GPCM provides battery voltage for approximately 2 seconds to rush current and heat up the glow plugs, then drop back to 7 volts lowering the amperage.
The glow plugs can operate up to 20 minutes.
The glow plugs may turn back on at cold ambient extended idle.
Old Sep 5, 2011 | 09:37 PM
fixdent's Avatar
fixdent
Even at -30 temps the glow plug indicator light only comes on for about 2 seconds....now waiting like the old beasts....
Gordon
Old Sep 6, 2011 | 04:03 AM
MNDiesel2's Avatar
MNDiesel2
Really -30 F, and only 2 seconds...I guess I could test that theory pretty easily in a couple months.
That plugged in or not?
Speaking of cold weather, are these trucks suppose to come with a grille blanket when sold in cold climate. A fellow worker said his 6.4 came with one, I don't know where it's hidden, and if mine came with one, or was supposed to or not..?? .
Old Sep 6, 2011 | 05:13 AM
dschuffert's Avatar
dschuffert
Mine didn't come with one. I bought this one from eBay last week. I am please with the initial look and feel, let's see if it holds up during the winter: 2011 Ford F250 F350 F450 F550 Winter Front | eBay
Old Sep 6, 2011 | 07:47 AM
Tom's Avatar
Tom
Couple of things here:
1. The manual says that the block heater is required for below -10°. It will start below that, but that's considered abuse by FMC. I didn't do it to mine, I suggest you not do it to yours. I have started mine at -10° before without block heater, but -11° or more and it was certainly plugged in.
Secondly, the 6.4L truck had a problem with snow clogging the air filter. This was their fix for the issue, they only issued winterfronts to trucks sold in the northern states. The 6.7L hasn't demonstrated this problem, and so we don't get one. I did foul my air filter in snow last winter though, it was in that nasty blizzard in December when we got 18" on that one Saturday. It can happen, drive accordingly!
