E4OD Shift Shaft Removal/Install Help!?
Old Sep 2, 2011 | 12:20 PM
Edgethis's Avatar
Edgethis
Exclamation E4OD Shift Shaft Removal/Install Help!?
Does anyone know how to remove the shift shaft (shaft the the MLPS sensor sits on and linkage mounts to) and install a new one? I'm really not wanting to tear the whole transmission apart and learn as I go. Any tips? Thanks
Old Sep 2, 2011 | 01:30 PM
White 97 xlt's Avatar
White 97 xlt
I'm not sure on the E4OD but I would think it would be about the same as a C6.. On the C6 you had to drop the valve body to give the shaft room to slide into the trans case..
Basically you dropped the valve body, removed the mlps/neutral safety switch (older models) then take the nuts off pull the shaft out from inside the trans.. Back when they had the kick down lever, it came loose from inside and slid out of the shift lever to the outside..
Old Sep 2, 2011 | 01:59 PM
Edgethis's Avatar
Edgethis
Hmm ok thanks. Is there anything involved with dropping the valve body or can I just pull it out swap the shaft and put valve body back in? I.e. no springs or ***** falling out...
Old Sep 2, 2011 | 02:08 PM
White 97 xlt
Again I have NOT had an E4OD apart, but have had quite a few C6's, C4's and older stuff in various degrees of dis assembly.. On the old C6 the valve body came as an assembly, there was a bolt or two (maybe more) on top that had to be taken out to separate it IIRC..
It's been about 10-12 years since I've been under a vehicle except to change oil or just give it a look-see.. And the old memory ain't what it used to be..
I hope some one who knows for sure comes along soon and corrects my mistakes...
Old Sep 2, 2011 | 02:27 PM
Edgethis's Avatar
Edgethis
Ok thanks again! I don't have to do this right away but I couldn't find any answers searching. Btw Im doing this to install a floor shifter. It requires a new shifter shaft. Im doing a how-to thread so everyone else has a reference if they wanna do one as well.
Old Sep 2, 2011 | 02:41 PM
Lazy K's Avatar
Lazy K
Can`t help much but going on exploded views, it would seem that the manual shaft is threaded at both ends. It would look like if the internal linkage was disconnected and the nut removed, then the shaft could slide outwards. However I don`t know what access to the nut is like from inside the case.
Old Sep 2, 2011 | 02:56 PM
Edgethis's Avatar
Edgethis
Correct the shaft is threaded on both ends. I have the new one to go off of.
Old Sep 2, 2011 | 02:58 PM
Edgethis's Avatar
Edgethis
...stupid phone. Anyway. I have the new one and yes its threaded at both ends but I don't know what its threaded to or the space around it as Lazy K mentioned. If I have to drop the valve body might as well look into a replacement and see if its worth upgrading while its out.
Old Sep 2, 2011 | 03:05 PM
White 97 xlt
There should be some flat spots on the sides that keeps the arm from moving on the shaft then threads for a nut.. If the shaft is not stepped, (larger on one end) (and big end going inside) you may have gotten lucky.. You might be able to remove the nuts and pull the shaft out of the linkage and out of the case in one motion..
I don't have a drawing so all I have is reference to C6's and memory.. (Boy, am I screwed)
Old Sep 2, 2011 | 03:22 PM
Lazy K's Avatar
Lazy K
Yes, the threads are for a nut that keeps the internal shift lever on the shaft. I`ll try to find an exploded view.
https://www.wittrans.com/Schematic.a...00&Schematic=4 The manual shaft is part No. 991-4.
Old Sep 2, 2011 | 03:30 PM
Edgethis's Avatar
Edgethis
Ok so basically it looks like the shaft goes into the trans, goes through part 991-3 and then gets a nut put on. Right? Just have to drop the valve body out of the way.
Old Sep 2, 2011 | 03:34 PM
Lazy K's Avatar
Lazy K
Right but may not have to touch valve body, may be enough clearance to get the nut and linkage off as is. Once you get the pan off all should be revealed.
Old Sep 2, 2011 | 03:41 PM
Edgethis's Avatar
Edgethis
Ok thanks alot. I wish I had a link or part number for that e4od pan with a drain plug..I hate not having one. And $300 for an aftermarket one is crazy. Ill drill and tap mine before that.
Old Sep 2, 2011 | 03:49 PM
White 97 xlt
You might check NAPA or maybe rock auto and look for a replacement weld in engine oil part.. It's rectangular/oval so the ends can be tacked to the inside of the oil pan, there is no reason you couldn't drill a hole and tack weld (might have to go to a welder) the plate in then insert plug.. Sure as heck a LOT cheaper.. Finding the weld in nut will be the hard part, since you'll already have the pan off the trans..
I've done this before but for the life of me I can't remember where I got the goodies. I'm almost sure it was NAPA, but it was MANY moons ago.
Old Sep 2, 2011 | 03:56 PM
Lazy K's Avatar
Lazy K
Search: transmission pan drain | Oil Drain Plug | AutoZone.com You could go with something like this or, as White says, get a weld in one.
