Clark Tranny
Old Apr 4, 2003 | 07:43 AM
snowfighter's Avatar
snowfighter
Clark Tranny
I posted this in Tranny section with some help but not exactly what I need. I'm looking for the part number or model number of the clark 5spd for a 79 F250 4x4 400 np 205. I heard they came out in 460 powerd school buses. Can anyone help?
Old Apr 4, 2003 | 11:27 AM
albertafarmer's Avatar
albertafarmer
Post Clark Tranny
Clark tranny are now owned by Dana. I got parts for mine at The Gear House in Edmontn, Alberta. Most tranny shops should be able to get parts for them.
Old Apr 4, 2003 | 10:48 PM
bigblue250's Avatar
bigblue250
Clark Tranny
If you are looking for an overdrive unit you need a 580V which can be found in f-600 and up, but so far the ones that i have looked at will only work with the FE's. Because you will need the bellhousing flywheel and clutch set up. The reason you will need these is because the Clark being a medium duty tranny has a larger input shaft there for requiring a larger 14" I think clutch disc which will not fit the flywheel of a light duty truck, which in turn will not fit in the light duty bellhousing(correct me if I am wrong). But anyway this is just from what research I have done. If you find any thing out about swapping one to a 460 let me know. Thats the only reason I don't have one now because I want a 460 in the future.
Old Apr 4, 2003 | 10:50 PM
bigblue250's Avatar
bigblue250
Clark Tranny
Whoops, my bad I thought you were looking for swap info not parts info.....sorry. Try Rockland Standard Gear in New York.
Old Apr 7, 2003 | 09:03 PM
SR71's Avatar
SR71
Clark Tranny
I asked if anyone has done this before but how about a 5 sp zf tranny out of a newer truck. From what I have gathered so far this tranny will bolt up to a 460 with the right bellhousing. Just need to change the tranny mounts. I think ford switched to the 5 sp late 88 or 89.
Old Apr 7, 2003 | 10:03 PM
fordguy76's Avatar
fordguy76
Clark Tranny
i did alot of research on this topic too a long time ago. i think someone has swapped a clark into a 4wd. i would like to know if i will work or if you have to change anything. i know with the zf's you have to have one from a 4wd. and i dont think they made any big trucks with a clark and 4wd. just like to know what you guys remember from those old post. me i wouldnt mind having a FE. i think they're great, they're just as good as a 460
Old Apr 8, 2003 | 01:31 PM
snowfighter
Clark Tranny
Thanks Guys for the help so far are the zf's a ten spline 1 1/16? Will they bolt up to a np205. I had orginally heard about the Clark on this site but I can't find out anything else.I run a 400 but its the same bellhousing pattern as 460.
retired ironworker
Large Truck
Oct 1, 2013 09:06 AM
f-61driver
Apr 11, 2006 09:07 PM
gary534
Oct 20, 2005 12:32 PM
jnorris
22
Dec 2, 2002 03:08 PM
