96 F250 AC problem question
Old Sep 1, 2011 | 06:51 PM
ctimrun's Avatar
ctimrun
During a long acceleration the AC vents turn off and the air blows out of the floor and defrost vents. When I stop accelerating and come to a steady speed if switches back to the vents where it should be. Where do I start and how much to fix it?
Old Sep 1, 2011 | 07:27 PM
White 97 xlt's Avatar
White 97 xlt
Sounds like a vacuum leak some where, the most common is the white plastic vacuum line that goes over the top of the heater/AC box under the hood to the actuator behind the passenger side hood hinge.. (Gets brittle and breaks)
If your vacuum reservoir is metal check the bottom of it for rust holes.
If it's very long acceleration with a load like a trailer going up a long grade there isn't much you can do about it. The reservoir just holds so much vacuum.....
Old Sep 2, 2011 | 11:07 AM
FordTruckin95's Avatar
FordTruckin95
Yeah, I had the same problem with my 95 F250 and it was a vacuum leak. Mine was the little white one on the passenger side.
Old Sep 2, 2011 | 11:26 AM
ctimrun's Avatar
ctimrun
Great! Doesn't sound too bad, thanks guys.
Old Sep 5, 2011 | 03:02 AM
ctimrun's Avatar
ctimrun
Crappy cell phone pic, but thanks to your advice I think I found the problem!
Old Sep 8, 2011 | 02:50 PM
ctimrun's Avatar
ctimrun
Anyone know where to get this vacuum hose? Tried several parts stores and Ford with no luck.
calixt0
Jun 22, 2017 06:49 PM
oldcoupe42
Aug 14, 2016 07:39 AM
now_what
Aug 27, 2015 09:09 PM
highteckredneck
Apr 11, 2012 01:20 AM
aws3230
13
Jul 4, 2008 09:55 AM
