285 or 265? Suggestions?
I did not notice a change in mpgs but also have 4:30's and do tow about the same weight as OP.
FWIW, my speedo is right on as per GPS with 265's. 2000 2WD V10.
That's why some mfg's with all wheel or full time 4 wheel drive say replace them all at once or at least have the new ones shaved down to within 5% of the old tires ! (but that would be dumb to do, correct? I mean buy new tires and then shave miles off them
)And yes even part time 4wd should have all four tires replaced at once or it's just hard on transfer cases.
Shave tires?????? That's just absurd unless you like to throw money away and if so throw it my way.
So yes I would agree on all counts!
right now with my excursion on 265/75s when the speedo says 75mph i'm actually going 71mph. same goes for my other fords stock..2-4mph is normal.
I've compared the SGII (reading RPM & MPH via ODBII)
with both the dashboard and the GPS...
The ODBII/SGII was exactly the same speed as GPS reported.
The speedometer was 3 MPH FASTER @ 70-75MPH than GPS & SGII.
Edit: The Ex is 3-4 MPH slower than the speedometer says, I was tired last night :-)
The trip meter/odometer seem to agree with SGII reported trip distances.
I reset trip meter, lie-o-meter, and SGII with each fill-up,
and after 700+ miles on a tank
they are both within 4-5 miles of each other. AND the SGII is within a few tenths of a gallon of how
much fuel I take.
This means the lie-o-meter is close with stock 265 tires
while the speedometer reads below actual MPH.
When you go to 285 tires most posters claim the speedometer is now
correct - because the RPMs of the engine/tires is lower thus the
computer thinks you are going slower.
But, that would likely mean the ODBII/SGII and trip meter
would be wrong, apparently resulting in the popular position that
285 kills MPG, because you are actually going FARTHER with each
tank than the odometer/ODBII/SGII thinks you are.
I'll be needing tires shortly, and if I go with 285s, I'll borrow an AE
and see if I can re-calibrate things to compensate.
that's my 0.02 - ymmv
