Need some help.
Old Aug 31, 2011 | 06:10 PM
Monte1go's Avatar
Monte1go
Need some help.
So, my slave cylinder went to crap and I have no idea how to remove it. I don't want to get down there and mess anything up as money is tight right now so I figured I'd ask you guys for some help. I'd really appreciate it.
Old Sep 1, 2011 | 07:25 PM
Franklin2's Avatar
Franklin2
Slave cylinder on the clutch? What engine do you have? The 460 and diesel where external, I believe the others were internal slaves and you have to pull the tranny.
Old Sep 2, 2011 | 02:47 AM
Monte1go's Avatar
Monte1go
Sorry, it's a 300 6 and I believe the tranny is a t-19. The slave cylinder is an external unit.
Old Sep 2, 2011 | 06:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All 1983/89 F Series & Bronco slave cylinders are external as are the master cylinders, but...
There are three different slave cylinders as it depends on the year/engine size/trans type.
E3TZ-7A564-A .. Slave Cylinder: 1983/89 F250/450 6.9L & 7.3L diesels; 460.
E4TZ-7A564-A .. Slave Cylinder: 1984/87 E/F150/350 & Bronco 300/302/351W / 1988/89 F150/350 w/Warner T-18 4 speed.
E8TZ-7A564-A .. Slave Cylinder: 1988/89 Aerostar/Bronco II/Ranger // E/F150/350 & Bronco 300/302/351W.
Old Sep 3, 2011 | 07:30 AM
Franklin2's Avatar
Franklin2
If yours is like mine was on my 89 diesel, it is a huge spring clip that holds it on the bellhousing. It sort of looks like those cheap clip on nuts the factory uses on the sheetmetal of the truck, only it's very large and takes a lot of prying with a large screwdriver to get it off.
Old Sep 3, 2011 | 10:35 AM
glovemeister's Avatar
glovemeister
Pry the large retaining nut off your clutch fork. There will be a dowel pin/roll pin that will be lodged in the side of your clutch slave holding your master cylinder hose in. Knock it out with a nail and a hammer or a pair of needle nose and a slave. Replace opposite of removal. Be forewarned that bleeding it will totally suck I just did this a month or more ago. Lots of cussing was involved.
Old Sep 3, 2011 | 05:50 PM
Monte1go's Avatar
Monte1go
I appreciate the replies guys. It finally came in today and I got it on in less than five minutes. Bleeding the thing is definatly a pain in the rear.
projectdagger
Sep 29, 2013 12:35 PM
privateer, eh
Mar 20, 2013 10:17 PM
CrazyFazy
Bronco II
Jan 18, 2004 09:23 PM
