Sponsored by: Auxito
battery light on
Old Aug 31, 2011 | 03:21 PM
sparke454's Avatar
sparke454
battery light on
had to rescue my daughter from the side of the road the other night. found out that her battery light had been on for a few days. upon getting the truck home I pulled the battery and started to charge it. Pulled the alternator the next day and had it tested and it checked out good. So i checked the ability of the battery to maintain a charge and it held a pretty decently. so i pulled alternator again and took it to a different store for testing and it checked out good again. re installed alternator and put a new belt on the truck. now when i pull the 3 prong plug on the back the light goes off. any ideas on what it could be?
Old Aug 31, 2011 | 11:50 PM
Bluegrass 7's Avatar
Bluegrass 7
Well it's not an idea but how the light works.
Battery voltage through the ignition switch goes to the lamp.
The lamp gets a ground from the alternator regulator switched on or off to control the lamp's on and off condition.
If the motor is running and the lamp is on, then you pull the plug, naturally the lamp will go off (if) the alternator is 'not' outputting enough to make the regulator open the lamp's ground. You did it by pulling the plug and taking the ground away.
The regulator is faulty if the battery charge voltage is up and in the normal range of 14 volts +/- with the motor running and the lamp is still on.
This is explanation #2. See Buzz44 post below.
Good luck.
Old Sep 1, 2011 | 06:51 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Alternators are not load tested at parts stores. So a bad unit can give a false pass on their test machine. The same goes with starter tests.
Old Sep 1, 2011 | 10:06 AM
Buzz44's Avatar
Buzz44
Morning just thought Id jump in here and ask another question pertaining to this question as a follow up to my earlier post. The question is are these newer alts rebuildable or is it just best to repalece it? In the day Id just get a new or rebuilt and replace it. Not even sure they make the parts or brushes to do any rebuilding for these.
Old Sep 1, 2011 | 01:13 PM
cv18sro's Avatar
cv18sro
Not sure. On my wifes 02 Escape when the alt when out and I took it off, it was totally sealed, I could not see how to get it apart. I just bought her a new one. The one on my truck still works but at quick glance it does look like it can be taken apart, surely someone has kits for them.
Old Sep 1, 2011 | 07:33 PM
Buzz44's Avatar
Buzz44
Autozone shows regulator and brushes available.
Old Sep 1, 2011 | 09:48 PM
sparke454's Avatar
sparke454
Bought a new alternator today and still the same issue. Throwing in the towel and taking it to a shop for them to diagnose.
Old Sep 2, 2011 | 05:59 PM
trober_603's Avatar
trober_603
well like some one said ealier they dont load test them at part stores so thats y its testing good and it could be a relay somewere thats going bad theres hondreds of things
stlf150
1997 - 2003 F150
Jun 3, 2017 05:57 AM
glemons42
1997 - 2003 F150
23
Mar 29, 2014 10:15 AM
medic25
Dec 10, 2012 02:20 PM
medic25
Dec 10, 2012 11:24 AM
j_n_l
Jul 20, 2006 06:48 AM
