I dont know whats wrong?!!!!
Old Aug 30, 2011 | 10:07 PM
342f100's Avatar
342f100
today me and my dad finished rebuilding my 1971 302 bored .40 over. Started on the first try after making sure everything was good n tight and toping off the fluids we went to drive it, when i put it in drive and started to accelerate it boged down and choked off. after starting it back up again it did the same thing over and over again. i Think it maybe the transmission holding it back because ive had problems acclerating before but notihng like this. but if you think there is something else wrong please let me know.
Old Aug 30, 2011 | 10:18 PM
79 shortbed lover's Avatar
79 shortbed lover
Sounds like maybe a float sticking in the carb. I would check that if it was me.
Old Aug 30, 2011 | 10:23 PM
meborder's Avatar
meborder
Just asking questions to prompt additional thought and input...
what does it do when you put it in reverse?
what about second?
don't know if it is a 2x4 or 4x4, but a stuck transfer case could cause some headaches.
could it be a massive vacuum leak? sometimes you need to retorque everything after getting the engine up to temp for the first time after a rebuild.
just getting the ball rolling ...
Old Aug 31, 2011 | 08:15 AM
fmc400's Avatar
fmc400
MSEE
What does "choked off" mean? Does the engine stall?
So far you haven't given enough information to indicate that the transmission is related to the problem.
Old Aug 31, 2011 | 10:20 AM
ctubutis's Avatar
ctubutis
I was asking the same.... a wheel bearing or driveshaft will not affect how the engine runs, but a poorly-tuned & running engine can sometimes have these kinds of problems.
My approach would be to verify the engine, seeing as how THAT is what was recently (majorly) changed on the thing. Is there fuel pressure, is the choke for some reason choking the engine, are the spark plug wires installed right, is the timing correct, are there no vacuum leaks, etc. etc.
There was nothing said if this is a 2WD or 4WD but I'd maybe be putting the rear end on jack stands and then trying to replicate the problem.
Another question for the OP - what, EXACTLY, does "rebuild" mean to you?
BaitsandBullets
29
Jul 9, 2018 04:21 PM
Tangentalone
Jun 26, 2009 12:22 PM
dragontoy22r
Jan 29, 2007 03:27 PM
Rmvr53
Jul 26, 2005 11:13 PM
73Custom
Feb 19, 2001 08:05 PM
