suspension for plow
Old Aug 30, 2011 | 02:48 PM
89ch's Avatar
89ch
suspension for plow
Just bought 1989 f 150 reg cab long box. a plow was added just before buying but it sits low in front. It has D-7 coil springs in front. I assume I will need a more hd spring and possibly shocks or air bags. which and what type? Am not a mechanic but pretty handy, can I do this myself?
Old Aug 30, 2011 | 03:57 PM
Bankrupter's Avatar
Bankrupter
How do you plan to plow this truck? Is this for your driveway or commercial duty. I know the ford fan boys will all give you options but the F150 was not built to plow. Driveway service, it will do fine for. But other then that you want a F250 + or your goning to be sorry when you kill that truck. Even my 95 F250-HD needed upgrades for plow service.
For light duty plowing I'd give it a set of air helpers that you can dump when done and keep the half ton ride for off season. I dont know if a SES system is made for the coil sprung trucks but know they work sweet in commercial plowing applications. My last 3 Ford city trucks all used them with excellent success and zero failures.
Old Aug 30, 2011 | 07:16 PM
Volvo92906's Avatar
Volvo92906
I agree with Bankrupter. The 1/2 ton was not really made for plowing on a commercial scale. And I am not even sure a 3/4 ton holds up perfect. Itll need more than springs to help it. With a 1/2 ton you will definitely need to do something about the suspension like ball joints. Plowing is hard on that stuff.
Old Aug 30, 2011 | 07:34 PM
GoinBoarding's Avatar
GoinBoarding
I've been told the driver side axle housing has a tendancy to snap/crack just outside the differential housing when these D44 TTB front end trucks are used for substantial plowing.
Old Aug 30, 2011 | 08:42 PM
kd0axs's Avatar
kd0axs
What you need is a set of air bags that go inside your front coil springs. My stepdad and stepbrother both plowed parking lots for several years with F-150s with no major problems and the only upgrade either of them made was these air bags. Of course, when it came time for new trucks they both upgraded to F-250s and I also got an F-250 when I got my drivers license and joined the business.
http://www.4wheelparts.com/Towing/Co...2&t_pn=FIR4102
An F-150 is definitely not the ideal truck for plowing, but if it's what you have it will get the job done. Suspension and driveline components take a beating no matter what kind of truck you have, but obviously you can expect to be replacing them more often on a 1/2 ton truck.
Old Aug 31, 2011 | 12:26 AM
TC-Countryboy's Avatar
TC-Countryboy
One thing you have to think about on these TTB front ends is that if you just go with heavier coils to carry the load, when you don't have the weight on the front end, it is going to lift the front end, throwing the camber off. Airbags would probably be the way to go, air them up when you have the plow on then defate them for normal everyday driving.
If you decide to go the spring route though, send me a PM and I will make you a deal on a set of lightly used heavy duty coils. Lets just say they are left over from an experiment that cost me a set of coils, considerable wear on a pair of front tires, and two trips to the alignment shop.
TC
Old Sep 5, 2011 | 09:02 AM
unibody62's Avatar
unibody62
Glad I came upon this post, because I am looking for a plow for my F150. I got rid of my garden tractor that I used to plow with and I thought would be able to use my truck to plow out my drive and a rental property. Sounds like everyone thinks it will hold up for light duty use (with front airbags of course).
Old Sep 5, 2011 | 10:51 AM
fordper4mance's Avatar
fordper4mance
Light duty plowing may work but as the other guys have said, it wont be optimal.
Old Sep 5, 2011 | 11:19 AM
f-trucker88's Avatar
f-trucker88
i have a plow on my 89 and have a similar issue with sagging. i took the set of coils off my 88 parts truck that never saw a plow a day in its life and it brought the truck up a good inche and a half. i like the air bag idea ive never seen it on coils. I have been considering just putting a solid axle d44 on the truck for the hell of it though! and yes an f150 definately is not a plow truck but you work with what ya got lol
Old Sep 5, 2011 | 11:56 AM
Jaime74656's Avatar
Jaime74656
Yep the F150s (light duties) arn't designed with plowing in mind, but if you really have to use it and this is what you got, use it, I would suggest putting bags in the front to compensate for the additional load, now there is a light weight plow thats about $1K-ish that might be a better solution as its made of heavy duty aluminum and rubbers and seems to work very well that may be another option if your plow is too heavy that may be more for lighter duty trucks.
Truck Snow Plow | Snowsport HD Utility Plow | Buy Snow Sport Plows
I don't have one but it may be worth looking into if your other plow is too much for the truck to handle...
Old Sep 5, 2011 | 12:52 PM
ta2rob's Avatar
ta2rob
Timbren makes heavy duty rubber products for front & rear suspensions.
I have a 1993 4x4 with Timbren front & rear. It works excellent. The Timbren pieces bolt on - no mods. Easy install. No maintenance either. Bolt them on & forget about them forever.
They act like heavy duty bump stops ... they sit on top of the axle housing at each corner of the truck. They stop the leaf springs from compressing too much.
They might have something for the front end of your truck.
They are not too expensive & the company's people deliver excellent customer service.
Old Sep 5, 2011 | 01:20 PM
bashby's Avatar
bashby
+1 on Timbren's, They are very popular in the snow plowing industry. Air bags would be better as long as they dont leak since you could set the pressure up when the plow is mounted... on board compressor would be a cool setup, but Timbrens are a lot cheaper and there is nothing to go wrong with them.
Old Sep 5, 2011 | 08:32 PM
Bankrupter's Avatar
Bankrupter
This is the SES stuff I mention in my first post also. Just realized I said SES only and not, Timbren SES. Sorry caz SES would get you no where in a search. My bad...
I'd add to this to say that " look" like a heavy bump stop but they act and are more of a rubber spring helper "like" an air bag w/o air. They don't effect the suspension till needed. Yet in the front of fords they look like that are always working.
Old Sep 6, 2011 | 09:33 PM
unibody62's Avatar
unibody62
Originally Posted by kd0axs
What you need is a set of air bags that go inside your front coil.
Firestone Ride-Rite Part 4102 - Coil-Rite Front Air Helper Spring Kit
I was looking at the air bags here, and it says they are not lift compatible. My truck has a 4" lift, does anyone know if there is another product that will work with a lift kit?
Old Sep 7, 2011 | 11:30 AM
gfwallace's Avatar
gfwallace
Adding weight behind the rear axle will take weight off the front. I carry about 700 lbs behind the rear axle in my F-250 with a heavy Western plow.
Jerry
