Sponsored by: Real Truck
towing
Old Aug 29, 2011 | 09:44 PM
900cfi's Avatar
900cfi
towing
I need to tow my truck and was wanting to know if a 2005 f-250 with the 5.4 would tow my truck on a car hauler.I have a 2007 dodge ram 4x4 quad cab.The weight is approximately 5400lbs for the truck and 2300lbs for the trailer.Thanks
Old Aug 29, 2011 | 09:56 PM
02ranch250's Avatar
02ranch250
i have an 02 f-250 with a 5.4 and have pulled a dodge grand caravan and a heavy duty pipe top goose neck trailer. the truck pulled it just fine just put the f-250 in tow mode or O/D off and go. Trailer breaks help alot when stopping but my controller was out when i pulld the mini van and i took it easy but you should be fine.
Old Aug 29, 2011 | 09:57 PM
Quad Racer's Avatar
Quad Racer
Sure it would. If I was pulling a dodge with my SD I'd atleast pull it through a couple dodge dealers on the way though. haha. An F150 could easily do it also.
Old Aug 29, 2011 | 10:01 PM
900cfi's Avatar
900cfi
I'm a ford guy and bought the dodge on a budget.I feel good getting towed by a ford.So much for those hemi motors.Blown at 74,000km.JUNK!!
Old Aug 29, 2011 | 10:03 PM
02ranch250's Avatar
02ranch250
heck i have 190,000 miles on my 5.4 and it runs great
it had 188,000 when i pulled the mini van
Old Aug 29, 2011 | 10:15 PM
Quad Racer's Avatar
Quad Racer
A couple of my buddies are Cummins boys and always bustin my chops for having a Ford and a gasser. I can't wait till I have to pull one of their rigs some day. haha. Hope it all works out and I dont mean to joke at your misfortune. Good luck to ya.
Old Aug 29, 2011 | 10:48 PM
Kajtek1's Avatar
Kajtek1
New F250 have towing ratings at 12,500 lb, so even the older model might have it slightly lower - the 7700 lb is still below the expectation.
Talk about lack of confidence in Ford
Old Aug 29, 2011 | 11:00 PM
kd0axs's Avatar
kd0axs
The truck will tow that no problem. At 7700 lbs, you aren't even close to the max tow rating.
Technically, you are supposed to use a weight distribution hitch for anything over 5000 lbs, but I don't think I have ever seen anyone use a WDH on anything but a camper trailer.
Pastor Scott
Nov 11, 2016 09:28 AM
carolinaborn82
All Things Towing
22
Aug 8, 2012 01:50 PM
drh1175
2009 - 2014 F150
Aug 1, 2010 11:07 AM
ecott_01
2009 - 2014 F150
Jan 27, 2010 08:57 AM
Rider8
Dec 10, 2008 02:47 PM
