Sponsored by: Auxito
Instr. cluster replacement
Old Aug 29, 2011 | 07:37 PM
chaser1602's Avatar
chaser1602
Just want to make sure I have this right after doing alot of searching. I need to replace my inst cluster on my 2000 f150 lariat. This can not be done without reflashing the computer by a dealer, right?
Old Aug 29, 2011 | 08:38 PM
projectSHO89's Avatar
projectSHO89
The replacement cluster will need to be programmed so your PATS keys will work with it.
If you just replace the cluster, the engine won't start until the anti-theft system is re-programmed with your keys.
Old Jan 7, 2012 | 05:20 PM
five_w_coupe's Avatar
five_w_coupe
How do I reprogram my used guage cluster so that my 2000 expedition will start?
Old Jan 7, 2012 | 07:17 PM
projectSHO89
Haul it to a dealer for reprogramming.
Old Jan 16, 2012 | 12:14 PM
five_w_coupe
Haul it to the dealer.
Why can't I pull out the computer, take the cluster and my key to them and let them handle it? It would be cheaper for me than having to call a towing service
Old Jan 16, 2012 | 03:54 PM
cjtim's Avatar
cjtim
just curious why you replacing the cluster?if its because of the odometer flickering on and off? theres a way to fix that with out replacing
Old Jan 16, 2012 | 07:16 PM
projectSHO89
Call the dealer and let them tell you what they think of that idea....
Old Sep 14, 2017 | 11:38 AM
five_w_coupe
I soldered the terminals instead of replacing the cluster. Much easier.
Thanks to all
Old Sep 15, 2017 | 09:24 AM
alloro's Avatar
alloro
Much easier.
Cheaper too!
Firefighter437
May 22, 2016 10:13 PM
jonathan mosher
2004 - 2008 F150
Jul 11, 2015 11:39 AM
dines78
Jan 1, 2011 09:43 AM
scottb1014
2004 - 2008 F150
Sep 6, 2004 12:16 PM
