To the People running the AIS
I love mine, my intake is spotless even after driving through some logging roads with lots of dust. It looks clean and the install is really easy, and the filters really do last a long time. I've read of guys getting 60k out of a filter, so the cost isn't terrible really. I like the fact that it's sealed from outside rain, and it flows plenty for my application.
Never saw any difference in performance or MPG between the two.
I also added the fender sleeve when I went back to the AIS.
Puredieselpower Fender Sleeve
Fender Sleeve Install If youre handy you can DIY the sleeve.
Before installing sleeve you need to be sure fender opening is clear.
I started with the 6637 but went to the AIS last winter. I was worried about rain water getting in, and with the exhaust and E99 WW that open filter would scream pulling up hills. I like how the AIS looks under the hood better, and it stayscompletely dry. I don't have a zoodad or fender sleeve, but since I'm on a stock tune I don't need it, and it works great for me as is right now.
I'm a fan of the AIS, great filt & looks like it belongs there.
Like Robin said get the fender sleeve then forget about it. There was a few places to get the filter elements for $55-$60 but you'll probably not need it for 2-3 years.
Never did try the 6637, I like to hear the radio when I'm driving...lol
I had an AIS and now it's sitting in the storage area because I went back to the 6637.
I could pull the filterminder to the second notch with a brand new filter whenever I would go out and take a trip with the trailer in tow.
Didn't like to see that much restriction even though I know it wasn't hurting anything.
The 6637 flows a lot better with just as good of filtration.
I've heard of folks moving the filterminder with a chipped truck, that's why I went with the fender deal right from the start.
I've also heard that the filter minder on the AIS is super sensitive, probably overly sensitive really. I bet a fender sleeve would fix it up.
I had to cut holes, mine maxed out to
The filter minder that comes with the AIS is overly sensitive. I found that the stock filter minder did not react nearly as much so I left the stock one installed. After adding the sleeve it has not reacted at all except after putting the skinny pedal to the floor.
If you install an AIS on an E99 you need a 99+ airbox to CCV coupler intake tube.
