Trailer Connection
Old Aug 27, 2011 | 03:23 PM
JonArmy's Avatar
JonArmy
Trailer Connection
I was getting ready to tow a TT before I committed to saying I would tow I was checking my plug, usually on the 7 plug, you'd have a 12V constant and then of course trailer brakes, lighting and such. My 12V constant was showing 0.0, so I checked everything else and with lights off 0.0, but with lights on around 12V. Most of the trailers I will be towing will need the 12V constant. I have checked the fuse panel pertaining to trailer connections and all the fuses are good, I still need to keep the lid open and test the turn signals and all. Before I have Ford waste $60 figuring it out I would like to steer away from them if need be. What should I try to so I can finally get stuff back on the road and such?
Old Aug 27, 2011 | 03:29 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
You might want to post in this area also. Lots of knowledge on towing and trailers.
Towing, Trailers & 5th Wheels - Ford Truck Enthusiasts Forums
Old Aug 27, 2011 | 03:59 PM
gjnicholas's Avatar
gjnicholas
was youre key on it only works with key on ran into that myself
Old Aug 27, 2011 | 09:14 PM
JonArmy's Avatar
JonArmy
I tried it both with these ways
engine off - no voltage
engine on - no voltage
I have to get some alligator clips so that I can confirm running lights, turning signals, reverse and brake controller
Old Aug 27, 2011 | 09:23 PM
Buckshot95's Avatar
Buckshot95
Well i had the same problem but i had a bad ground and all i did was i got out a ginder and ground down the spot i wanted to put my ground wire and the i didnt have any problems.. but i did have to put my running lights connected to my licence plate wiring
Old Aug 27, 2011 | 10:04 PM
gjnicholas's Avatar
gjnicholas
one of the pins on the 7 pin conector is a ground make sure it has a good conection to ground
Old Aug 28, 2011 | 06:53 PM
JonArmy's Avatar
JonArmy
I have checked ground on both the 7 and 4 connection, they are good, I am planning on going to a trailer shop that I trust and see if they can figure it out, I have worked with them before. Most likely the person who had the truck before me accidently snipped one of the wires.
Old Aug 28, 2011 | 06:57 PM
dchamberlain's Avatar
dchamberlain
Did you check the trailer tow fuses?
Old Aug 28, 2011 | 07:08 PM
JonArmy's Avatar
JonArmy
I checked at least 4 fuses, they were good, now if I over read and missed on, then my mistake, should there be 4 or 5 fuses?
Old Aug 28, 2011 | 07:23 PM
dchamberlain
On a 2004,
#6, Trailer Turn/Stop lights
#38, Trailer Park lights
#39, Trailer Backup lights
#101, Trailer Brake Controller power
#115, Trailer Battery Charge (this is the 12V feed one)
Make sure you test the fuses, don't rely on a visual inspection. You can use a test light and test the in place by probing where the blade is exposed on the back of the fuse. Or you can take the fuse out and use a continuity meter.
Relay #305 is the Trailer Battery Charge Relay.
You can use a standard test light to test the plug, hook the alligator clip to the ground pin then test the other pins. The diagram is on the plug cover. Or you can see a diagram here.
Trailer Wiring Diagrams | etrailer.com
Old Aug 28, 2011 | 07:36 PM
JonArmy's Avatar
JonArmy
I'll check tomorrow and if my job needs me to tow something this week I'll tell them to write me a check to get new fuses. Hopefully it's just probably fuse 115, cause 5,38,39, and 101 are good, I must of missed the 115 fuse by mistake, I think I was outside in the heat trying to figure it out.
Old Aug 28, 2011 | 11:50 PM
Cowboy65's Avatar
Cowboy65
Also check out the following link which shows the truck electrical diagram for the fuses and relays listed by above by dchamberlain.
https://www.fleet.ford.com/truckbbas...bb_pdf/189.pdf
Old Aug 29, 2011 | 05:32 AM
JonArmy's Avatar
JonArmy
This morning before heading to work, took a look at 115, even without testing or pulling it out I could tell it was blown, thanks everyone.
magnoliarunner
Jan 17, 2018 11:16 AM
BassFantasizer
Aug 21, 2013 12:42 PM
jjlrrw
All Things Towing
Dec 19, 2011 08:54 AM
jjlrrw
Electrical Systems/Wiring
Dec 9, 2011 02:28 PM
JonArmy
All Things Towing
Aug 30, 2011 07:58 PM
