TPS? Please help! ABS? Injector?
Old Aug 29, 2011 | 07:53 PM
subford's Avatar
subford
Originally Posted by Alec94F150XL
Also the ECT works because it tells the temp correctly. Like it'll change when I turn the a/c on/off.
How do you know that?
Do you have a scanner hooked to it to read the ECT voltage?
The information from the ECT sensor ONLY goes to the computer.
Old Aug 29, 2011 | 08:05 PM
Alec94F150XL's Avatar
Alec94F150XL
Well I'm assuming, because whenever I work it hard, it get hotter, like the gauge. Also like said before it'll move up a tad bit when a/c is on/off.
I've noticed the truck runs alot cooler and it doesn't even generate alot of heat anymore. Can hear when the water pump engaged when I first replaced everything. (Radiator, thermostat, water pump, both hoses)
Old Aug 29, 2011 | 08:18 PM
subford's Avatar
subford
The ETC sensor has nothing to do with any gauge, it only sends temp information to the computer. The ETC sensor has two wires on it.
The one for the TEMP gauge is the temp sender and it only has one wire going to it.
Old Aug 29, 2011 | 09:07 PM
Alec94F150XL
Ok I'll look into it tomorrow. I'm just stumped on the whole hesitating and bucking part.
Old Aug 29, 2011 | 09:30 PM
subford's Avatar
subford
The ECT code could have come from a cold engine when the codes were scanned.
Old Aug 29, 2011 | 09:50 PM
Alec94F150XL
The engine was cold when codes where scanned. I'll exchange the TP sensor tomorrow. Lifetime warranty.
Old Aug 29, 2011 | 10:41 PM
hoss khaos's Avatar
hoss khaos
Just a suggestion, My old Ford did the same thing and it was my EGR valve sticking. When I shut the engine off, it took awhile to fully close. I don't know why it did that. It could be jamming up, or the Vacuum regulator for it could be failing. I remember hearing a whistling noise too I just blocked mine off and never bothered checking it. That is like a big Vacuum leak and will cause sluggish low powered driving and bad/stalling idle.
Old Aug 29, 2011 | 11:09 PM
Alec94F150XL
But I can turn my truck off then on and it'll run perfect and idle perfect. It's got me stumped! In one of the post a guy said the TPS resets every time you start it up. So I think it might be that.
I don't know, I'm really thinking of selling it honestly. But if I can fix this problem within the month, I'll keep it. I'd hate to part with it.
Old Aug 30, 2011 | 06:00 AM
subford's Avatar
subford
Deleted Deleted
Old Aug 30, 2011 | 04:21 PM
Slip ford man's Avatar
Slip ford man
You could have a funky computer...I replaced mine and had codes come up that were never there with the old one. Maybe your computer is at fault with the on/off thing you do. Swap in a reman if you try it, cost about 120. for me, Car-quest...try taking off the battery neg cable for a half hour.
alsatropine
2004 - 2008 F150
Feb 13, 2017 11:11 PM
vze2sgxa
Feb 22, 2014 09:59 PM
pgjeepster
Aug 15, 2012 06:15 PM
Rackpatrol
Nov 28, 2005 04:00 PM
