Not much power... plugged cat?
Old Apr 3, 2003 | 06:12 PM
bigric's Avatar
bigric
On the '92 351W, I've noticed that it's got a lot less power than I think it should have (like other 351s or 302s I've driven). I don't have a check engine light, I've replaced all the filters, wires, plugs, cap, rotor, I've run injector cleaner through it, and I'm wondering what to do next. I'm wondering if I should suspect a plugged cat, and if so, how can I check it out without removing it? I've heard that if you hook up a vacuum guage and start the engine and the vacuum steadily drops off for the first minute that you should consider a plugged exhaust system.
