1978 - 1996 Big Bronco
1978 Ingnition By-pass
Old Aug 28, 2011 | 02:03 PM
outlawbob's Avatar
outlawbob
I want to by pass the factory control box...there is no smog controls of any kind on the engine.....What is the easiest way to do it
thanks
bob
Old Sep 1, 2011 | 09:28 AM
Edgethis's Avatar
Edgethis
Are you just looking for a way to start the truck without going through the normal operation? If so, you can wire a switch across the starter solendiod on the fender. That will bypass the key switch.
Old Sep 1, 2011 | 09:59 AM
outlawbob's Avatar
outlawbob
I want to eliminate the factory stuff..I bought a mallory distributor..electrical box..coil..
I think the heads have carbon built up it pings when I open the throttle....timing appears OK..only does it when the engine is up to temp...
plus low oil pressure..5-10 # at warm idle..not good
thanks
Old Sep 1, 2011 | 10:23 AM
Edgethis's Avatar
Edgethis
Well I wouldn't worry about the ignition components until you resolve the pingin and oil pressure issue. Id make sure your timing is good. For the oil pressure. Test your sensor to make sure its accurate first. Throw some seafoam in the engine and make sure its full of oil. The oil pump itself may be going out. If so you'll have to drop the pan and swap it out. Then you could also check for sludge in pan or on pickup.
Old Sep 1, 2011 | 10:38 AM
outlawbob's Avatar
outlawbob
running mechcanical oil pressure guage..thought of the pump replacement..going to use top end cleaner for the carbon...2v heads were notorius for this...just a project in the works..cam bearings could be worn also..
thanks
Old Sep 1, 2011 | 04:25 PM
husker's Avatar
husker
I run 15-40 diesel oil in my 78 400 with good luck. Better oil pressure and good cleaning qualities for an older engine. I also do the same in my 64 Tbird.
Old Sep 1, 2011 | 09:06 PM
outlawbob's Avatar
outlawbob
good to know, will try it..did a cleaning with sea foam..let see what happens
N8RdaGR8R
May 5, 2019 04:06 PM
Drew Lagman
Nov 6, 2012 11:23 AM
hillbilly delux
Mar 14, 2008 08:21 PM
OldFords
17
Jun 4, 2007 03:03 AM
Kanute
Aerostar
Feb 18, 2005 04:18 PM
