Need help!
Old Sep 11, 2011 | 06:47 PM
jorge.s's Avatar
jorge.s
Change the TPS; no luck. Can some one tell the symptoms of a bad idle air control valves. Thanks
Old Sep 11, 2011 | 08:16 PM
Beatertruck's Avatar
Beatertruck
Its generally a surging at idle.
How did you check for an exhaust restriction? Please be specific....
Old Sep 12, 2011 | 06:02 PM
jorge.s's Avatar
jorge.s
Well I can count that out.
Is any expert around that can suggest something else. I really don't have a clue on where to look next. I can't believed this truck is missing so bad and I don't get any code.
I just put it on gear with the brake on ; hit the gas pedal and it start missing like is running on 3 cylinder. Same when I take it to the road. It 's undrivable.
Old Sep 12, 2011 | 06:09 PM
Beatertruck
Did you use a back pressure gauge? Did you remove the cats? Or did you just put your hand over the tailpipe and go "yep, there's exhaust coming out"?
Old Sep 13, 2011 | 03:02 AM
cj06's Avatar
cj06
can you isolate an single cylinder that is not firing ? if so then you will have a problem with that one ! and it could be a injector , valve train or valve problem ! if it is missing on a cylinder then check the compression and then do a leak down test !
Old Sep 13, 2011 | 08:41 AM
timbersteel's Avatar
timbersteel
I notice that 1 question wasn't asked.
-When did this truck start exhibiting this behavior?
I agree on the last 2 postings for backpressure and cylinder compression.
My '92, 300, had the same problem your's is having with "1" exception. It started after we got 22 inches of snow here and it had sat for 3 weeks not being driven. It started fine and when I would give it gas it would jerk, buck, sputter and literally act as if it was gonna puke all over the road. Well, as seeing nothing had changed before I had parked last, I managed to get it to the nearest road and keep working at it. I dumped in several ounces of MMO, well, more like 10 (which is A LOT!!) and filled the tank up with Shell 93 octane, about 6 gallon's worth and kept working on it. It would idle ok and as soon asI started to give it gas, it just did everything your's has done. After letting it run for a few hours, I shut it off. tried it again the next day. Wasn't as bad, but still was trying to puke all over the road. Let it run for another hour and a half. Shut it off. I did this for 2 days and somehow, it finally quit. I have no idea why it started, but being persistent cleared it up. This was my daily driver and I think that sitting for weeks on end without starting contributed to it. My money is bet on either bad gas or just having sit to long and the injectors are clogged and/or dirty.
Old Sep 13, 2011 | 10:15 AM
jorge.s's Avatar
jorge.s
I will try it (Tibersteel) This truck has been my daily drive for the last ten years. It has two fuel tanks but 98% of the time I run the rear one cause the sending unit on the front one don't work, but I always keep it fuel. I switch to the fuel tanks only when the real it get near 1/4. I has never run it on less than a 1/4 of thank. (rear).
It start to act like this about two weeks ago when I was on a stop sing and got on the gas to get on the main road quit, it felt like the tranny or rear end was falling apart; it won't go, Right after that it was doing it every time I got on the gas.
When I change the fuel filter And drain it I notice the gasoline was black like it was use to wash part. After read your post it just remember it and I believed that maybe some injectors are clogged.I will check on this and post the finding. Thanks
Old Sep 24, 2011 | 07:11 PM
jorge.s's Avatar
jorge.s
OK;
A. It looks like the # 1 cylinder is dead; no change when pull plug wire,(new plug). Change with another plug and no change. Unplug hardness from #1 cylinder injector and no change. Test the injector hardness with a test light and has power getting to the injector.
B. I hear this noise (like a spark noise) there is no sparks anywhere. I track it down to the coil frame with the Stethoscope. When I put the Stethoscope on the coil frame is when I can hear the clicking more lauder and some on the sensor under the coil.Can the coil be bad or going bad?
Any ideas? For now I probably will check on that injector. If anybody
has any suggestions I will appreciated. Thanks
PS. Fuel issue fix; New pump and new sending unit.
Old Sep 27, 2011 | 11:15 AM
jorge.s's Avatar
jorge.s
OK; I pull all the plugs and run a compression test:
Results; #1 to #3- 160 PSI
#4 - 165 PSI
#5 - 170 PSI
#6 - 165 PSI
I'm running out of ideas, can I get some help here? I will change the injector on #1 cylinder to see it helps but any suggestions will be appreciated. Thanks
fordka
Jan 21, 2013 01:31 PM
JR636
Jun 28, 2011 06:07 PM
Born24wheel
Jan 18, 2007 06:13 AM
sirkeithc
Jan 15, 2003 08:22 PM
Saxon
Feb 23, 2002 08:55 AM
