Adjust parking brake
Old Aug 27, 2011 | 08:41 PM
lexustbs's Avatar
lexustbs
Anybody know how to tighten up the parking brake? Mine is just not holding on hills.
Old Aug 27, 2011 | 08:43 PM
720Deere's Avatar
720Deere
Is that how it ended up in the drink?
Old Aug 28, 2011 | 12:35 PM
mhoefer's Avatar
mhoefer
Tree is a drum brake inside the hat of the rear rotor. Inside the backing plate there is a slotted rubber bung, pull that out and use a wide flat screwdriver or a brake spoon and turn the star wheel inside to expand the distance between the tops of the e brake pads. The star wheel also should adjust when stopping in reverse, but sometimes this takes some extreme stopping. The star wheel is threaded at both ends so a small adjustment moves the pads apart a fair bit so try only a turn at a time. If you place the brake on, then unjust to tighter, then relase and try setting, you will be sure you are turning the start wheel in the correct direction.
afinepoint
Sep 7, 2012 08:03 PM
ptaylor-01
Jan 8, 2012 10:26 AM
OneTon4Fun
Jan 25, 2011 05:02 PM
dcf4x4
Dec 20, 2007 10:14 PM
raykjavik
May 7, 2006 06:34 PM
