Tie Rod Info
Old Aug 27, 2011 | 04:30 PM
robert leagh's Avatar
robert leagh
Tie Rod Info
Hey guys. I have a beautiful to me, 1973 Ford F600. Original paint. Old 330 industrial., with a 5 speed, and a 2 speed rear. It's an old roto rooter truck with a 1300 gallon water tank, and a rooter designed pump powered by an IH six cylinder mounted back by the hose drums. I hauled 1100 gallons out to my ranch(that's it's new job), and pumped the water in to my holding tank. Didn't even sag the springs. I'm impressed.
The road is a bit harsh though, and the little beauty needs attention(replacement) of the drivers tie rod end. Napa says there are 3 different ones.Vehicle weight of 6000, 7000, and I think 9000 lbs.
My original registration says it's 6400 lbs. GVW is like 19,872(loaded, max.)
The reg says F60DVQ627xx. I'd like to have the right part when I go up next time. Any pointers on a part# for the TR end?Drivers side. I'd sure appreciate any input. Thanks in advance. Robert
Old Aug 27, 2011 | 04:36 PM
Lil Red Sled's Avatar
Lil Red Sled
Is there a way you can take it off and bring it up with you so you can compare?
Old Aug 27, 2011 | 08:09 PM
robert leagh
Thanks for your response. Yes, I think that is the best way to go. I will remove the TR end next trip, and install the new one on my next time up there. That way, I'll be sure to get it right. The whole king/link suspension looks beefy under there, and the TR end looks to be industrial strength. That's good. I had to make a quick exit last trip to attend a Calfire water tender course in Redding. I'm a class A driver, and my boss needs me to have the cert. The end didn't pop out, but it has the looseness, I could feel it in the steering wheel, and when I push/pull on the end. It's a very BIG steering wheel. Love that old Ford truck. Still has the original owners manual in the glovey!
NotSoSporty98
13
Nov 28, 2015 08:47 PM
kxbronco
Dec 19, 2006 08:21 AM
East Side
1983 - 2012 Ranger & B-Series
May 10, 2003 06:19 PM
Stiers
Aerostar
Apr 7, 2002 01:53 PM
bigricker
16
Nov 24, 2001 08:28 PM
