My new lighting mods!
Old Aug 28, 2011 | 01:12 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Same deal on my ODO too...WTF....
And I have the red lights under the dash also....Swapping over to grey interior again...So it's all goin grey an blue now...
Old Aug 28, 2011 | 06:57 AM
Jaime74656's Avatar
Jaime74656
Originally Posted by Midnite1987
what he said.
i took a pic of my guages with the truck cold and just started. the hard one is the speedo. trying to put the needle on while driving and looking at the gps for the speed at the same.... tool me about 5 min once i figured out how to hold my tongue right.
to clean the green off i used a scotch brite pad (the maroon one) and a couple drops of water and it cleaned it off just fine. just hold it up to thew light to check very often. you only want to go enough to remove the green not too far and make thin spots the light will shine through. ( i tried the scrape with knife method but found that the scotchbrite worked WAY better)
i have the ebay led bulbs in mine and it workes pretty good. my only complaint is that the odo doesnt really light up with the red
i also did under dash lights
yea ill just find an FTE member who can help with this, Ive already tried on 5 experiment dashes and fugged them up bad... I also have bad hand shake issues when i try this but Ill keep getting these things from the yard till i get them right LOL!
Old Aug 28, 2011 | 05:48 PM
UncleCracker302's Avatar
UncleCracker302
[quote=xc4jokestomper;10743270]well i got my new headlights in and my new dash gauge bulbs as well. my headlights still need to be reaimed because their too low but they still work decent. im going to order the bumper and corner lights that match sometime whenever the budget allows.
what color did you do for the lights? LEDs?
Old Aug 28, 2011 | 09:09 PM
xc4jokestomper's Avatar
xc4jokestomper
For my headlights? Their some kind of hid appearance lights i got from harbor freight that was on sale.
Old Aug 29, 2011 | 09:40 AM
UncleCracker302
oops! sorry, i meant for the dash? were they blue leds?
Old Aug 29, 2011 | 11:30 AM
Midnite1987's Avatar
Midnite1987
Did you get the actual headlights or just the bulbs?
If the headlight do you have a link to them?
Old Aug 29, 2011 | 02:03 PM
xc4jokestomper
Yeah i used blue leds for the dash.
The headlights i got off of ebay. Just type in "95 f150 smoke light" and they should come up
Old Oct 23, 2011 | 12:12 PM
GHeTTo JOe's Avatar
GHeTTo JOe
so when putting the needles back on the gauges you have to adjust the speedo? and do you have to remove the black back cover before removing the green film or can you just clean it off of the exposed areas?
Old Oct 23, 2011 | 12:40 PM
Jason Lewis's Avatar
Jason Lewis
Originally Posted by 86F150302
I want white needles now... Stupid Lightnings with their orange needles! Kinda scared id screw up when putting the new needles on and my fuel gauge or speedo or tach would be off..
Wish i had Orange needles it would match my Auto Meter gauges !
Old Oct 23, 2011 | 04:53 PM
Midnite1987
You have to remove the needles and peel the black guage face carefully off the guage. Look at the back and it is obvious where the green is to clean off. Try not to clean too much tho. Do a little then hold it up to a light till there's no green left visible. The speedo was a pita to get right. Trying to drive on the hwy while holding gps and place the needle back in the right spot all at the same time is not easy lol. Take the truck for a drive before you take anything apart to get it to proper operating temp an take a picture of where all your other gauges are so you can put them back on in the same spot...
Old Oct 23, 2011 | 04:57 PM
SideWinder4.9l
That the easiest one...Simply turn the key off...And lay the needle on the left peg..Put on and it'll correct it's self....
Old Oct 23, 2011 | 05:05 PM
Midnite1987
Really?! I fought with it for a good 1/2hour to get it right
Old Oct 24, 2011 | 01:55 AM
  #28
SideWinder4.9l
Yeap...Because if you put the needle on the little thin metal tip, with the white part of the needle resting on the peg under 0mph....When the key is turned on, the needle will jump up to where its supposed to be...
Note-Be VERY firm with putting the needle back on...I had mine to slip back off going down the road, after I'd reassembled everything...>.<
skidmarks82
1997 - 2003 F150
May 6, 2022 01:08 PM
thegenco12
Appearance & Dress-Up
Jul 6, 2016 09:30 PM
War Hammer
Oct 26, 2012 05:02 AM
projectbad78
Apr 13, 2008 12:41 AM
