Oil Change???
Old Aug 26, 2011 | 06:38 PM
Jlckb5's Avatar
Jlckb5
Oil Change???
Ok just bought my 05 Expedition with 86000 miles. Anyone have any reccomendation on what type oil is should use? Ford Synthetic or Synthtic Blend? I believe the manual says blend, I think the truck was carried for reg. oil changes at dealer. Was thinking of doing it myself.
Thanks
Old Aug 26, 2011 | 07:31 PM
Beechkid's Avatar
Beechkid
MC semi................
Old Aug 27, 2011 | 12:00 AM
lv2race's Avatar
lv2race
5W-20 MC blend 5qt jug + 1 qt is cheapest at Wally Mart.
Old Aug 27, 2011 | 02:47 PM
alloro's Avatar
alloro
Ford recommends using 7.0 quarts of 5W-20 Premium Synthetic Blend Motor Oil.
But they also have the following footnote: Use of synthetic or synthetic blend motor oil is not mandatory. Engine oil need only meet the requirements of Ford specification WSS-M2C930-A and the API Certification mark.
Old Aug 27, 2011 | 08:09 PM
alwaysfords41's Avatar
alwaysfords41
I only get 5.5 quarts in mine, that's all Ive ever gotten in it. I always change the oil scalding hot as well, so it is draining down.
Old Aug 28, 2011 | 02:47 PM
Jlckb5's Avatar
Jlckb5
In the process of changing oil , do I use 6 qt or 7 qt??? Also, do I need to reset the info center after the oil change?
Thanks
Old Aug 28, 2011 | 03:09 PM
alloro's Avatar
alloro
Up through 04 an oil and filter change took 6 quarts. Your 05 is supposed to take 7 quarts when changing both the oil and filter. To be safe, put in 6 quarts, run the engine to fill the filter. Then shut it off, wait a few minutes, then check the oil level and fill it as needed.
Old Aug 28, 2011 | 03:18 PM
Jlckb5's Avatar
Jlckb5
What about the info center, I don't think anything will need to be reset there.
Old Aug 28, 2011 | 05:21 PM
Jlckb5's Avatar
Jlckb5
Ok weird thing checked oil at 6qts. oil level is right at the top of the XXXX just below the top hole on the oil stick. Is this normal? My owners manual also said 7qts, should I add another quart???
Old Aug 28, 2011 | 06:59 PM
alloro's Avatar
alloro
NO, do not go over that top mark.
Old Aug 28, 2011 | 09:59 PM
Jlckb5's Avatar
Jlckb5
Wonder why Ford would have put 7qts in owner guide if it was full at 6 qts.
Thanks everyone for your help.
HarleypsychRN
2004 - 2008 F150
19
Dec 10, 2010 02:41 AM
johnmsch
2009 - 2014 F150
16
May 13, 2010 01:13 PM
nebmike
Jan 17, 2008 06:32 PM
nsaikia
2004 - 2008 F150
Jun 25, 2007 04:14 PM
axl_james
3.0L V6
Aug 1, 2003 07:06 AM
