Shift Detent - Part Located!!
Old Aug 26, 2011 | 09:16 AM
EffieFord's Avatar
EffieFord
Lookit what I found...
Automatic Shift Column Lockout Plate, 73-77 Ford Bronco, New - Toms Bronco Parts
I know in that thread about Shift Detent - the part that causes the Auto Trans to drop into Reverse out of Park - NumberDummy noted that no one makes one and there is not one to be had by Obsolete Dealer. Just noticed it lists for a 73-77 Bronco, but the part looks exactly the same as the one pictured in this thread - https://www.ford-trucks.com/forums/1...ft-detent.html
Being that I'm into Broncos and write for the Bronco magazine, I wind up with Bronco catalogs. Even though my primary interest is the Fullsize Broncos, I'm starting to find that some of the parts for our 66 F100s can be found through early Bronco vendors.
Naturally being that the first year of the early Bronco is '66, some of the '66 F100 parts wound up on the Broncos.
Anyhow... that detent thing is very important, I'll be ordering one soon.
Old Aug 26, 2011 | 09:53 AM
Tobys351.9's Avatar
Tobys351.9
Reasonable Parts
It looks like most of his parts are reasonably priced too.
His online catalog is not crowded, looks like a good supplier although I didn't check out the shipping cost yet, a few things that I need are several dollars less than most places.
Not too many places carry that column shift tube, I was looking a few months back and ended up buying a very good used one for $25.
Thanks for the link!
Old Aug 26, 2011 | 11:21 AM
EffieFord's Avatar
EffieFord
They're based out of Oregon, and ship FedEx ground, so to Atlanta, it was about $18 shipping. I bout fell off my stool, but whatever... I wanted that thing and ordered it.
The other thing I want is the cigar lighter. It drives me nuts - because I'm OCD - that there is no bezel that says "lighter"... its just a silver circle... So I've been looking into putting a different lighter in the dash so I can have that dang bezel. I don't understand why they don't make one, or didn't have one in the trucks... grr. Maybe its just me.
Old Aug 26, 2011 | 01:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by EffieFord
Lookit what I found. D2TZ-7A216-A = Automatic Shift Column Lockout Plate, 73-77 Ford Bronco, New - Toms Bronco Parts
NumberDummy noted that no one makes one and there is not one to be had by Obsolete or FoMoCo Dealer.
Go right on ahead and order it, but when it doesn't work, don't blame me.
It may look the same, but looks can be deceiving.
C5TZ-7A216-A .. Detent / 1965/66 F100/250.
D2TZ-7A216-A .. Detent / 1972/77 F100/350 / 1973/77 Bronco.
1967/71 F100/350: There are two others, they aren't the same either.
If you invest in some Ford parts catalogs, you won't make this mistake again.
The 1965/72 & 1973/79 Ford Passenger Car Parts Catalogs & the 1964/72 Ford Truck Parts Catalog are available on CD's from hipoparts.com
Bronco parts are listed in the car catalogs thru 1979.
Originally Posted by effieford
The other thing I want is the cigar lighter. It drives me nuts - because I'm OCD-that there is no bezel that says "lighter"
The bezel is swagged onto the element, cannot be replaced by itself.
How many would'ja like? 1961/66 F100/1100 & 1966 Bronco used the same element: C1TZ-15054-A
Ford replaced C1TZ-15054-A with C7TZ-15054-A in 1967, then replaced C7TZ-15054-A with D3TZ-15054-A in 1973-used thru 1979.
All will work, but C1TZ-15054-A is slightly different than the other two. Carpenter has the D3TZ element.
Both the C1TZ element and the 1961/66 F100/1100 & 1966 Bronco "**** & Element" (C1TZ-15052-A) can be found NOS.
Old Aug 26, 2011 | 01:58 PM
EffieFord's Avatar
EffieFord
Dude. I wouldn't blame anybody for something *I* ordered with my money, and if its *my* mistake, then I'll take responsibility for it. I guess I considered it taking one for the team, because I don't mind ordering it and finding out for myself.
I have the Ford parts catalog on CD, as well as Microfiche, because as you know, I work at a Ford dealer, in the parts dept. It honestly never crossed my mind to look it up. I just saw it in the Tom's Bronco catalog and it looked the same and I thought I'd give it a try.
I really see no reason for you to get your drawers in a wad over *my* mistake and *my* money.
When it gets here and its not the same and it won't work, then I'll update the thread accordingly to save some other poor soul from making the same mistake. Chill out.
While I'm at it with all this spare time on my hands, I'll take the automatic column out of a '68 I have and see what it looks like, too. Cause I have a curious mind and I like figuring out Ford engineers brilliant ways to screw with people. I see it every day when I'm looking up parts.
Old Aug 26, 2011 | 02:09 PM
NumberDummy
It isn't just you I'm concerned with. Since you said it would work in 1965/66's, peeps are gonna assume that's correct...but it isn't correct.
Sorry, I had forgotten you worked at a dealer. Also forgot something else. I do respect women, wouldn't have been so in-your-face if I remembered.
Detents: 1967/68 is C7TZ-7A216-A, also fits some 1969's, but there is serial number break in 1969 (before/from D96,001). So, some 1969's use C9TZ-7A216-A, as do all 1970/71's.
If you want the correct lighter element and/or the **** and element, I'll be happy to list the sources.
Old Aug 26, 2011 | 02:15 PM
EffieFord's Avatar
EffieFord
I realize that, and I would have made sure to come back and correct it so as not to lead anyone astray...because I would not want that to happen to me.
Its all good.
I may look at that later, that's more of a "want" and not a "need."
Old Aug 26, 2011 | 02:27 PM
NumberDummy
Yes, I'm sure you would. But, what happens between the time you order it, then receive it, then try and install it...and then you discover it's not correct?
In the meantime, others may order one.
Old Aug 26, 2011 | 03:13 PM
CropDusterMan's Avatar
CropDusterMan
I recently installed the shift detent plate I pulled from a 79 Ford F250, and all I had to
do was gently file a tiny bit off of the right side of the plate for it to fit into the slot...
I'm talking a tiny bit. Works like a charm.
EffieFord, I'd also have a look at your shift lever portion that rests in the detent, as it
may be the issue with wear....did you see our other thread on it...check it out)
https://www.ford-trucks.com/forums/1091088-update-on-auto-shift-detent-my-repair-worked-too.html
Old Aug 27, 2011 | 08:55 PM
66CustomCab's Avatar
66CustomCab
...If you want the correct lighter element and/or the **** and element, I'll be happy to list the sources.
I'm looking for one of these, or a repro if they're available cheaper.
Old Oct 8, 2011 | 06:03 PM
66f-100's Avatar
66f-100
I'm curious, did this part work or not? We never got the update.
Old Oct 9, 2011 | 07:21 AM
EffieFord's Avatar
EffieFord
I haven't done it yet. I have the part laying on my desk.
The only thing I have to say at this point, I will not buy from Tom's Bronco Parts again. The shipping was ridiculous for a part that isn't even in any kinda package. It was wrapped up in a ton of brown paper and stuffed in a box that's way too big for the thing and charged some ridiculous shipping fee... for something they could have easily shipped in a padded envelope for a fraction of the price.
I have one more cruise in before I start to tear into the steering column. I just didn't want to get in there and somehow disable the truck right now, but I assure you, as soon as I get into the project I will take pics and update.
UnderPSI
WTB - Parts & other
Dec 11, 2014 03:08 PM
salf100
Apr 27, 2010 04:47 AM
66f-100
Oct 27, 2009 07:19 PM
Alex from GA
Aug 15, 2008 07:04 PM
rb76543
18
Dec 11, 2007 01:07 PM
