speedo change
Old Apr 3, 2003 | 02:33 PM
Fordnite302's Avatar
Fordnite302
speedo change
just got my new 35" tires and lift wanting to change speedo to correct speed. printed off the sheet telling me how from this forum, but i cannot find the wire it specifies, anyone know exactly where it is or if it might be different colors. thanks
Old Apr 3, 2003 | 09:02 PM
vman's Avatar
vman
speedo change
I think it's light blue\yellow under dash under glove compartment.
Old Apr 3, 2003 | 10:30 PM
steve83's Avatar
steve83
speedo change
Did you read this thread?
Old Apr 4, 2003 | 08:56 AM
Fordnite302
speedo change
ive read the thread and know what color the wire is i just cannot physically find the wire.
Old Apr 4, 2003 | 04:32 PM
Fordnite302
speedo change
I have found 3 wire connectors under the dash, there are 2 female black W/orange connectors, and one female/ blue,red,white,and greed wires. would either of these be the one. Please help, thanks
Old Apr 4, 2003 | 11:44 PM
steve83's Avatar
steve83
speedo change
No, as I said in that thread, it's a single-wire connector. Should be just below the L edge of the glove box.
Old Apr 4, 2003 | 11:52 PM
steve83's Avatar
steve83
speedo change
(*@#^$DOUBLEPOST!$#!*_!@&
Old Apr 5, 2003 | 11:43 AM
Fordnite302
speedo change
so its just supposed to be a blue with yellow stripe wire hanging below the glove box!?
Old Apr 5, 2003 | 12:04 PM
Fordnite302
speedo change
i have looked and there is not a single wire below the glove box that is yellow and blue. does anyone have a pic of what it might look like!!!??
Old Apr 5, 2003 | 05:15 PM
steve83's Avatar
steve83
speedo change
Fordnite
I'm uploading the page out of the '93 EVTM that shows the location of the connector. It'll be in this album in a few minutes. If you need a higher-resolution version, send me a real e-mail or a PM with your real e-mail address. Make sure to remind me what you need in that message.
by tim_30043
I have a 2000 F-150. Speedometer is only 10% off. I would like to get it back on the correct speed. Do I have to take it to FORD Dealer to do this?
From what little I know about '97-up OBD-II systems, any code scanner can reprogram the speedometer on that truck, and many parts stores offer that service free now.
Old Apr 5, 2003 | 07:08 PM
tim_30043's Avatar
tim_30043
speedo change
Steve
Thanks I will try that.
Tim
Old Apr 5, 2003 | 08:20 PM
MustangGT221's Avatar
MustangGT221
speedo change
Mine is just a little connector that says "PSOM" on it.
Old Apr 6, 2003 | 04:03 PM
Fordnite302
speedo change
is it possible that it might be a 91 model computer because, i have searched and pulled apart wire loom on the passenger half of the vehicle and i cannot see a single wire nor one with a connector that is blue and yellow. is it behind the glove box area? do i have to take things apart to get to it? can anyone help me?
Old Apr 7, 2003 | 06:34 PM
Fordnite302
speedo change
i figured out what wire it was its one if my black and orange connectors under the dash. although there is still a problem. i pressed the reset button speedo needle went up and back it displayed E 03 i pressed reset again and the conversion cal came up it was 918 i need 7..... but it started counting up not down and its now at 1039. i tried to do it again and it will not let me change it it will not flash again. can anyone help?
Old Apr 8, 2003 | 08:37 PM
Fordnite302
speedo change
just incase anyone cares anymore i finally got my speedometer recallibrated. for starters my psom connector is black w/orange not blue w/yellow. Thanks to a friend at a local ford dealership (gave me speedo diagram). grounded wire and started to re-callibrate but it went up not down. so i stopped and tried it again and it would not. apparently the speedo had been reset 6 times ( go figure). Luckily i had bought and extra gauge cluster off of ebay for $15. i swapped out the speedometers, and grounded the wire, IT WORKS!!! Got the speedo recallibrated and i am done for a while hopefully. Thanks for putting up with my **** and trying to help me.
Thanks,
Jeff
centralNH
26
May 12, 2014 06:42 PM
hwm3
Jul 29, 2010 03:45 PM
Gypsy99
Computer Chips & Tuners
Apr 10, 2010 04:37 PM
1950gmcelc
Feb 16, 2009 01:57 PM
Deacon Stanley
Nov 9, 2004 10:13 AM
