Truck exploded huge fireball
Old Aug 25, 2011 | 10:30 PM
fishman002's Avatar
fishman002
OK. Now I have your attention. I have posted this question twice without one response. I figured you all would respond to something exciting so I wrote a new title. Pretty catchy Huh? Anyway, I need some help with the following problem:
I have a 2000 7.3 auto 2 wheel drive dually crew cab truck with 455K on the body and 170K on the replacement engine. It has a new IDM controller, main computer, and CPS. I seem to have a percieved miss when hooked to a loaded trailer, foot off of the brake, truck creeping forward with no pedal pressure. I can "feel" each pulse of the engine as the cylinders fire. Is that normal or do I need to start looking at under valve cover harnesses, fuel injuctors,, etc? Also, truck is hard to start when cold even in warm weather. It takes two cycles of the key without waiting for the glow plugs to heat up, to get it to start if it sits more than a few days.
Thanks.
Old Aug 25, 2011 | 10:35 PM
WA.Ranger's Avatar
WA.Ranger
Sounds more like a tranny issue, need a little more info. Oh, and the others will be along with some good advice.
Old Aug 25, 2011 | 10:36 PM
Bonanza35's Avatar
Bonanza35
Why do you not wait for the glow plugs to warm up. Its required on these engines. Does it miss anyother time or just at idle under a load? Chet
Old Aug 25, 2011 | 10:49 PM
ff1210's Avatar
ff1210
I live in Tn and once I have cranked my truck for the day I never wait for the glow plugs to go off I just get in and crank it up.I have had no issues to the date even in winter time. It could be your LPOP.
Old Aug 25, 2011 | 10:57 PM
snakedoc's Avatar
snakedoc
the long starts may be weak fuel psi. bad pump or clogged filter in tank.
Old Aug 25, 2011 | 11:09 PM
ff1210's Avatar
ff1210
Snake you could be on to something with all the miles it has on it.
Old Aug 27, 2011 | 08:27 AM
ff1210's Avatar
ff1210
Bump to the top
Old Aug 27, 2011 | 01:32 PM
HD Rider's Avatar
HD Rider
I would check fuel pressure post filter for the hard starting issue.
The percieved miss could be from the CPS. You might try the origional black one (if you can find one) or the IH blue one to see if that helps. Other than that you will need to do some data logging with a good scanner to diagnos further.
Old Aug 27, 2011 | 09:09 PM
fishman002's Avatar
fishman002
Good point. The fuel pump question had crossed my mind. It is pretty dirty externally so I am guessing it too has 455K on it. How do you check fuel pump pressure?
On the LPOP question, are you thinking that the HPOP reservoir drains back to the sump and the LPOP takes a minute to fill it back up to operate the injectors after it sits a few days? I think I can check the level by removing the plug in the top of the reservoir.
Could it not be the kackle injector #8? I checked the cylinder balance with my Diablo Preditor and all of the cylinders look pretty even except for the infamous #8 plus I do not get any codes when I scan it.
I am going for 500K+ on the odometer. I need to keep her together a little longer!
Old Aug 27, 2011 | 09:13 PM
fishman002's Avatar
fishman002
I live in Louisville, KY. Same type of weather. I can go out during the summer mornings and kick mine right over without waiting on the glow plugs until just recently, even with the 455K on the truck.
Old Aug 27, 2011 | 10:51 PM
snakedoc's Avatar
snakedoc
yes you can take the plug out and check the level. to check fuel psi you need to put a gauge on the fuel bowl. the plugs in pic. you will need a fitting 1/8" FNPT to 1/8 npt. you can get one here Replacement O-rings for Ford Diesel Engines the high plug is pre filter low is post filter.
99whiteford
Apr 6, 2018 11:41 PM
DJHoff
Oct 2, 2016 06:46 PM
bajafishnut
18
Jul 25, 2015 04:43 PM
ALedbetter1
15
Apr 8, 2013 10:22 PM
Steve(ON)
Jul 22, 2007 07:28 PM
