Ignition Timing
Old Aug 25, 2011 | 10:15 PM
Redponymc's Avatar
Redponymc
Unhappy Ignition Timing
I'm new here and this probably has been answered 100 times, but, I need an answer. I transplanted a 302 out of a 1985 F150 into my 74 Bronco and I'm looking for timing specs. It has a Holley 4V carb with a hose to PCV at valve cover off the rear base plate, C4 auto trans, power brakes and some off brand electronic distributor with vacuum advance but no other vacuum operated features. It starts and runs good but I don't know what the initial timing should be set at. I set it with a vacuum gauge. Any help is appreciated!
Old Aug 25, 2011 | 10:19 PM
ctubutis's Avatar
ctubutis
Setting the timing with a vacuum gauge isn't a bad idea, and your initial timing is gonna be something between 6-10 BTDC.
Of course, this depends on your elevation.
Click on User CP in the top-left corner and finish filling out your Profile so we can see where you are, OK?
nlareau
Aug 26, 2011 08:10 AM
1986F150six
Nov 8, 2010 05:54 PM
towtruck
13
Dec 14, 2004 12:12 AM
KJKozak2
May 22, 2004 03:43 AM
kilo
Jan 22, 2004 09:18 PM
