Cruise control quit working
Old Aug 25, 2011 | 02:26 PM
89broncoll's Avatar
89broncoll
Cruise control quit working.1999 psd auto 4x4.won't do anythig.
Old Aug 25, 2011 | 02:32 PM
Duck Hunter81's Avatar
Duck Hunter81
You may want to check out your pressure sensor on your brake booster (it is a white plastic piece that is on the engine side/front). Mine went out and I lost my cruise control. Replaced it and was good to go. They are pretty cheap too. You can probably test it (I don't know how) but for the price it is worth just replacing it.
Old Aug 25, 2011 | 03:14 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Mine did the same thing and I did what Josh just said and it fixed the problem.
Old Aug 25, 2011 | 03:47 PM
PaysonPSD's Avatar
PaysonPSD
There is a recall on the CC cancel switch. If you haven't had it done it's a freebie.
I just bought the kit and replaced it rather then let the dealership do it.
Old Aug 25, 2011 | 07:13 PM
89broncoll's Avatar
89broncoll
Where did you buy the cancel switch kit at?
Old Aug 26, 2011 | 07:45 AM
Duck Hunter81
Is the recall for replace the switch? I thought it was just an inline fuse harness that they installed.
Old Aug 26, 2011 | 07:50 AM
Duck Hunter81
I bought mine at the local dealership.
Old Aug 26, 2011 | 10:57 AM
PaysonPSD's Avatar
PaysonPSD
If the switch looks good they just install an inline harness with fusible link. The kit I got at the dealership came with the switch and harness.
Old Aug 26, 2011 | 02:38 PM
89broncoll's Avatar
89broncoll
Can I get a picture of this switch?can't seem to find a white plug in or anything on brake booster.
Old Aug 26, 2011 | 03:53 PM
PaysonPSD's Avatar
PaysonPSD
Its mounted on the master cylinder. At the end and underneath. The switch screws into the master cylinder.
Old Sep 2, 2011 | 01:45 PM
89broncoll's Avatar
89broncoll
Took my truck in today, and the td me there's no recall showing on my truck?so anymore ideas Guys?thanks
Old Sep 2, 2011 | 02:47 PM
SpringerPop's Avatar
SpringerPop
Check for recalls for yourself on your truck at:
Recall Information
Have the VIN handy.
Pop
Old Sep 2, 2011 | 04:01 PM
miller_feed
Only cost me 27.00 for the sensor with the new fuse.
Old Sep 2, 2011 | 09:33 PM
bjvagts's Avatar
bjvagts
Check all your tail lights even the one on the cab.
Old Sep 4, 2011 | 12:00 PM
PaysonPSD's Avatar
PaysonPSD
Physically check to see if you have the new switch and/or harness. If not then Ford should do the recall.
The new harnes plugs into the stock harness and then the switch. Easy to tell.
