Rear window won't open
Old Apr 3, 2003 | 12:42 PM
stubborn1's Avatar
stubborn1
I can't get the rear gate window open on my 98 Explorer. I push in the lock release button and nothing happens. It hasn't opened since I bought the vehicle a year ago and fixing the window is on my spring project list.
Is there a way to manually release the locking mechanism from the inside? I need to unlock the window in order to remove the door trim panel. Once I have the trim panel off, I'm sure I can replace the lock mechanism.
Old Apr 4, 2003 | 11:00 PM
CobraXP's Avatar
CobraXP
The '98 has a different rear door than mine, so I am kind of stabbing in the dark. On mine, there is a snap-in piece above where the glass catch pin comes into. If I pop that cap off, I can get to the locking mechanism and can get it to release. Does yours have this?
Old Apr 5, 2003 | 01:05 AM
ford_tr_man's Avatar
ford_tr_man
i think the 98-up has a electonic thingy in there that releses it but im not sure
Old Apr 6, 2003 | 03:34 PM
stubborn1's Avatar
stubborn1
I can pop off the plastic cover to see the top of the lock mechanism. I am wondering if I can pry the metal piece back on the lock mechanism that latches onto the metal u shaped piece from the window. It doesn't want to move easy and I wasn't sure if I could safely force it open or on.
On the other hand, I'm going to be replacing some of the lock hardware anyway so I may go outside and pry away. Its already broken so I figure I can't do much worse
19golfer55
Escape & Escape Hybrid
Oct 25, 2017 05:44 PM
Olafs 7.3 ex
Aug 29, 2016 09:24 PM
Littlejon
1997 - 2003 F150
Mar 12, 2016 03:54 PM
Elmo154
May 15, 2011 10:33 PM
DSMMH
Mar 8, 2010 11:01 AM
