transfer case
Old Aug 25, 2011 | 12:48 AM
zakk's Avatar
zakk
transfer case
will the transfer case from my diesel bolt up to the exact same truck just gasser?
Old Aug 25, 2011 | 01:31 AM
ford390gashog's Avatar
ford390gashog
YES!!! Well that was an easy answer! There is some things like slip yoke vs. flange mount to deal with but the t case will bolt up its the driveshafts to worry about.
Old Aug 25, 2011 | 01:38 AM
zakk's Avatar
zakk
how about the 5speed from the gasser to the diesel?
Old Aug 25, 2011 | 01:40 AM
ford390gashog
Nope!! The pattern is different BUT you can try to adapt a 460 ZF 5 to a IDI by drilling out some holes. It has been done
Old Aug 25, 2011 | 03:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
no gas to diesel will not work the gas trans is not built as strong as the diesel trans.
there have been reports of diesel ZF to 460 modifications, but i would not ruin a trans by drilling it.
i would sell the gas trans and buy a diesel one.
Old Aug 25, 2011 | 12:27 PM
NorthernDiesel's Avatar
NorthernDiesel
Just to confirm, as I was wondering this too, the T-Cases will swap between diesel and gas models? Does auto Vs. standard mean anything to the T-Cases then?
Old Aug 25, 2011 | 01:02 PM
snaponprofile's Avatar
snaponprofile
Speaking of TC's how do you fill it and how much ATF does it take?
Old Aug 25, 2011 | 01:13 PM
tjc transport
i ain't rite
transfer cases do not care what trans they are bolted to. ford transfer case bolt patterns are all the same.
i have a BW 1356 case out of a 351 powered F150 in my 88 diesel. it now has over 200,000 miles on it.
i blew the original t-case in the truck around 270k miles.
the only thing done to it was a rebuilding before i put it in since it had around 150,000 miles on it when i got it.
Old Aug 25, 2011 | 06:37 PM
bashby's Avatar
bashby
I think they hold about 2 quts of atf, 3 should be plenty. I get one of those caps that comes on the gear oil bottles and screw it on the atf botlle, stick it in the filler hole and squeeze the bottle. You can get most of the fluid out of the bottle this way.
Old Aug 25, 2011 | 10:17 PM
vfelix702's Avatar
vfelix702
heres some info
heres the capacities list for our trucks....
________________________________________
CAPACITIES:
Engine, with filter..........9.9 quarts [1]
Cooling System, Initial Fill..........29.1 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, E4OD Initial Fill..........8.5 quarts
Automatic Transmission, C6 Initial Fill..........6 quarts
Automatic Transmission, AOD Initial Fill..........3 quarts
Automatic Transmission, Total Fill
3 speed C6..........11.9 quarts
4 speed E4OD..........15.6 quarts
4 speed AOT..........12.3 quarts
Manual Transmission, M5OD-R2..........7.7 pints
Manual Transmission, 4-SPD BW T18-19..........7 pints
Manual Transmission, 5-SPD ZF..........6.8 pints
Manual Transmission, S5-42..........6.8 pints
Manual Transmission, 5-SPD Mazda..........7.7 pints
Differential, Dana 44 Front..........3.6 pints [2]
Differential, Dana 50 Front..........3.9 pints [2]
Differential, Dana 60 Front..........6 pints [2]
Differential, Dana 60-IU Rear..........6.4 pints [2]
Differential, Dana 70 EX HD Rear..........6.6 pints [2]
Differential, Dana 70 HD Rear..........7.4 pints [2]
Differential, Dana 80 Rear..........8.5 pints
Differential, Ford 10.25 RingGear Rear..........7.4 pints [2]
Differential, With 8.8 or 9 RingGear Rear..........5.5 pints [2]
Transfer Case, Warner 1345..........6.4 pints
Transfer Case, Warner 1356..........4.1 pints
[1] When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
[2] Fill to no more than 1/4 to 9/16 inch below fill plug hole.
TORQUES:
Oil Drain Plug.....28 ft/lbs
Manual Transmission BW T18 4-SPD
Fill Plug 25-40 ft/lbs
Manual Transmission
Fill Plug 25-30 ft/lbs
Drain Plug 25-30 ft/lbs
Transfer Case
Fill Plug 12 ft/lbs
Drain Plug 12 ft/lbs
__________________
10strokin
Jul 17, 2012 12:20 AM
deadeye01
Dec 12, 2007 07:53 PM
buffalobob
Nov 20, 2005 04:45 PM
rxfx101
May 14, 2005 11:46 AM
stang88
Jun 14, 2004 10:25 PM
