97 psd wicked wheel
Old Aug 25, 2011 | 01:02 PM
Talyn's Avatar
Talyn
I can have mine off in 15 mins.
Old Aug 25, 2011 | 01:12 PM
Jfg21078's Avatar
Jfg21078
Wow that's pretty cool I kind of look forward to doing it now. I like how mechanic shops try saying its going to take 9 hours labor. I just haveto get the wheel now.
Me impeller has little chunks missing from where it got chewed up.do you guys think that will really have a big effect on performance?
Old Aug 25, 2011 | 01:15 PM
DIYMechanic's Avatar
DIYMechanic
Mmmm....YUP! Sure will!
Old Aug 25, 2011 | 01:23 PM
bad12jr's Avatar
bad12jr
the first time it took me 4 hours to get off and get all the bolts loose. Lots of swearing was involved and thrown tools.
Old Aug 25, 2011 | 02:01 PM
Talyn's Avatar
Talyn
It makes the it unbalanced.
You can pick one up from RiffRaff for a really good price.
I got mine from clay when I over torqued it and stripped it.
I can get mine off in 15 mins mostly due to having the EBPV delete as well.
But if you got the right tools and have done it a few times, You can still get it off fairly quick.
You can go the other route and sneak a wrench under the pedestal and unbolt the turbo from the pedestal and it comes out a lot easier.
just remember to take the bottom exhaust nuts off before taking the bolts out of the top. The top bolts hold tension off the bottom nuts.
Hit it with some PB blaster then some fluid film when you break it loose. the Fluid Film will lubricate the part and break down the rust further getting it off easily.
Old Aug 25, 2011 | 02:04 PM
Talyn's Avatar
Talyn
Yeah, it took me a bit the first time I did it.
I figured out how to finesse the wrench onto the drivers side bottom nut and get it off easily. but if your good at welding, you can make a tool that will do the job better.
Have not had a chance to try my new wrench I found in the dirt one day.
Ended up being the right size and looks like the bend on its perfect for the nut.
I also suggest breaking all the pedestal bolts loose before doing anything to the exhaust, that way they are easier to get up.
Once you got the exhaust part loose, you'll have to use a pry-bar to lift the turbo while taking out the rear pedestal bolts, cause you'll need to get them to move funny so they don't hit the exhaust y-pipe.
They always seem to come out easier than they go in for me.
Old Aug 25, 2011 | 02:05 PM
Talyn's Avatar
Talyn
Oh!
don't forget to order all new o-rings for the pedestal and turbo when you pull it and do the impeller.
You cannot re-use the o-rings.
You'll see why when you get it off.
Only time you can re-use them is if you just put it back on and haven't ran it for too long.
Old Aug 26, 2011 | 08:54 PM
Jfg21078's Avatar
Jfg21078
Damn all I have to say is you are freakin awesome. That's a lot of helpful info. Thanks. ..one more question about the ebpv delete. I recently had this sensor replaced but what is the benefit of getting rid of it and how would you do it?
Old Aug 26, 2011 | 09:09 PM
bad12jr's Avatar
bad12jr
Been in your shoes and know how much the info helps. The ebpv will help the exhaust flow a little better. Need to remove the valve in the turbo by grinding the rivets off. Then go find some one you know with a tig welder and cut off the actuator on the back. Then fill above the oil jackets not in them. The turbo will die quick. Then put a freeze plug in the shaft hole on the turbo. That's the gist. Ill see if I find the post I used.
Old Aug 26, 2011 | 10:19 PM
Talyn's Avatar
Talyn
I got a post somewhere. i just didn't take enough pictures to put it on my website.
Old Aug 27, 2011 | 06:33 AM
427 fordman's Avatar
427 fordman
https://www.ford-trucks.com/forums/9...pv+rod+removal
I did the method gobstopper did
Old Aug 28, 2011 | 03:06 PM
Jfg21078's Avatar
Jfg21078
Does anyone know a site I can get the o rings. Are they the same as the pedestal o rings?
Old Aug 28, 2011 | 03:18 PM
  #28
427 fordman
dieselorings.com yes iirc
Old Aug 29, 2011 | 08:17 AM
  #29
Talyn's Avatar
Talyn
Yeah, guzzles is the way to go.
You can order his stuff though clay as well if your ordering your wheel from clay and just get it all in one shot.
quesey
18
May 29, 2013 05:49 PM
stainlessstroker95
21
Jul 26, 2012 05:51 PM
murrhee
Mar 27, 2011 05:02 PM
mollikate
May 11, 2009 10:57 AM
Reptar360
Sep 20, 2005 01:09 PM
