600 or 750 for a stock 390
I didn't think i'd finally buy a 600cfm carb for my 390 till next year, but saw they were on sale at summit so i decided to go ahead and do it. Engine just has headers and the holley dominator intake. The carb i bought is a 1406 edelbrock. Everyone here seems to suggest the 600cfm for a 390, and 750 (what i had on it previously) was too much. Well after a short drive with the 600 on, it seems as if the truck has a little more off the line grunt, but everything else seems to be the same if not, not as good as the 750. It was only a short drive so i cant make any hardcore comparisons, but i felt that the 750 let the engine wind up a little faster....
Let me know what you guys think and have to say if anything.
I'll take it out for another spin in a few days to really mess around with it and see how it does again.
The carb seemed to work fine, just thought the 750 did a LITTLE better with taking off out of the equation.
The standard 428 also used the 600 CFM carb. Any bigger carb is a waste of time and money because the engine will not turn enough RPM to need more. The 390GT also used a 600 CFM carb and it made max power at 4800 RPM.
well figured i'd put this out there if anyone feels like answering, both carbs did this. If i press the gas pedal to the floor from idle, it backfires through the carb some then keeps idling still. What is causing this? I thought maybe it was just too much carb with the 750, but even with the new 600 it does it to. timing?
11-01-2013 08:06 AM
7636074460
04-02-2012 03:55 PM
tandm19992000
21
02-22-2007 08:27 AM
