CPS and DP
Old Aug 23, 2011 | 03:50 PM
wuttrd's Avatar
wuttrd
CPS and DP
i just ordered a gray and a dark blue cps to see witch works better. my black one is shot and 159.00 on ebay is robbery. hope the ones i ordered will work for me. any thing that i need to do with my tuner
Old Aug 23, 2011 | 04:08 PM
JOHN2001's Avatar
JOHN2001
Nope your fine swap it
Old Aug 23, 2011 | 04:09 PM
wuttrd's Avatar
wuttrd
cps
good to know thanks for the reply
Old Aug 23, 2011 | 04:14 PM
JOHN2001's Avatar
JOHN2001
I would try to get a old of Clay and see when hes expecting some in stock. I need a back up for myself
Old Aug 23, 2011 | 04:17 PM
wuttrd's Avatar
wuttrd
clay
good idea that sure would be nice if hr could get more
Old Aug 23, 2011 | 05:06 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
They aren't in production anymore. We were just fortunate enough to buy out International of what they had.
Old Aug 23, 2011 | 05:23 PM
JOHN2001's Avatar
JOHN2001
GREAT!! Which one is the next best?
Old Aug 23, 2011 | 06:28 PM
bulla's Avatar
bulla
Rumor that the blue cps affects the timing a lil. I'd like to see what Jody has to say about it. Clay told me the blue cps is internationals and was and is used in the 466 in line 6 cyl diesel commonly found in ______ size trucks. What do you call a truck larger than an F550? Like the F750 or internationals school bus style trucks.
Old Aug 23, 2011 | 07:40 PM
wuttrd's Avatar
wuttrd
dead again
well on the way home today my truck decided to die again what gives . i put the gray one in that the dealer me with the recal last night, and that did not work. well might be somthing else. ran ok to work but when i was on the way home came to slow down tach droped and died !! so what else could it be ??? could it be a heat issue temp out side was 114* not as hot as it has been HELP WHAT NEXT
Old Aug 24, 2011 | 07:25 AM
wuttrd's Avatar
wuttrd
help post #9
bump
Old Aug 24, 2011 | 07:42 AM
mueckster's Avatar
mueckster
Have looked at your wiring above the DS valve cover for the 42 pin connector? You could have a wire/wires chafing to ground. Another possiblity is an overheating IDM.
Old Aug 24, 2011 | 08:14 AM
wuttrd's Avatar
wuttrd
idm
thank you, i will check it out. will that show up on a AE? i have a buddy that has a AE to check it out hopefully today .
Old Aug 24, 2011 | 08:21 AM
mueckster's Avatar
mueckster
It is possible for a code to be stored. Have you checked for codes? Not all codes set a SES light and we are not always aware that they are there.
Old Aug 24, 2011 | 08:33 AM
wuttrd's Avatar
wuttrd
SES
did not throw a SES light when it happened all three times. each time it happened i was on the hwy, when i was slowing to pull off i would watch the tach. going in to coast the tach would drop below 500 then die. i can put it in to natural and fire it right back up not fun to steer or stop without power. trying to get it fixed before the wife has to drive it. thanks for the help
mueckster's Avatar
mueckster
Also, check your IPR coil and wiring. The nut is known to come loose or off and the wires can also chafe there.
